If the ColorPASS or the imagePASS is attached, you cannot open the Advanced Box to the public using SMB. To open the Advanced Box to the public, set WebDAV.
If the machine shuts down when a client computer is writing a file to the Advanced Box, an incomplete file is generated inside the Advanced Box. In this case, perform the operation again after restarting the machine.
To connect to the Advanced Box that is opened externally as the WebDAV server from a computer, depending on the operating system/software environment you are using, it is necessary to install the following update program.
For Windows XP or Windows Vista
Update Software Program for Web Folder: KB907306
For Office XP
Microsoft Office XP Service Pack 1 (SP-1)
For 2007 Office system
2007 Microsoft Office system Service Pack 1 (SP-1)
For more information, see the Microsoft Web page.
Authentication
Preferences → Network → SMB Server Settings
Function Settings → Store/Access Files → Advanced Box Settings → Authentication Management
Log In Using Touch Panel Display
Log In Using Client Computer
Use SMB Server
SMB Authentication Settings → Use SMB Authentication
On
On
On
Required
Required
On
Off
On
Required
No access
On
Off
Off
Not required
Not required
On
On
Off
Not required
Required
Authentication
Preferences → Network → TCP/IP Settings → Use WebDAV Server
WebDAV Server Settings → Authentication Type
On
On
Basic
Required
Required
On
On
Off
Required
No access
On
Off
Basic
Not required
Not required
On
Off
Off
Not required
Not required
