Original
Copy/Print
Output
TL Code
The dots are printed in the background of output.
QR Code
A QR code is printed at the specified print position on the output.
* The illustration of the QR code is a sample image.
TL Code:
A TL code is a type of 2-dimensional bar code. A TL code is printed and by changing the arrangement of the dots, digital information is embedded on the output.
QR Code:
A QR code is a matrix-type, 2-dimensional bar code developed by the DENSO WAVE INCORPORATED. Using a QR code, digital information is embedded on the output.
You cannot use both a TL code and a QR code at the same time. Specify the Document Scan Lock settings beforehand, such as whether to restrict scan job or not, and which code to use to restrict the scan job. (See "Selecting the Code for Document Scan Lock (TL Code/QR Code).")
Copy/Print
Scan Lock Information
Copy/Send/Store
Jobs are restricted.
Tracking Information with TL Code
Copy/Print
(Original)
Copy
(Original)
Tracking Information with QR Code
Copy/Print
(Original)
Copy
(Original plus Latest)
QR code carries information stored both in the first embedded QR code and the latest embedded QR code. According to this feature of QR code, if you copy the output which is already printed QR code and embed the new QR code on it, condition set for the Document Scan Lock mode will never be lowered than the previous one. For example, even if the latest scan lock information is set to [Allow All], the first scan lock information embedded in the QR code is [Prohibit All], [Prohibit All] is applied for the next Document Scan Lock mode.
Copy/Print
Original with Embedded QR Code and Secure Watermark
Copy
The embedded text becomes visible
This mode can be used only for printing a file stored in a mail box.
Please note that Canon will not be held responsible for any damages caused by the use of the Document Scan Lock mode or the inability to use the Document Scan Lock mode.
Use STMT size or larger. Do not use paper with a low whiteness level, such as colored paper. Do not use paper with high transparency, such as thin paper, transparencies, or tracing paper. Make sure to use the correct paper size and type to effectively use the Scan Lock Information and Tracking Information. (See "Available Paper Stock.")
