This mode can be used only for printing a file stored in a mail box.
Make sure to set the paper type correctly, especially when using heavy paper or other special types of paper. If the type of paper is not set correctly, it may adversely affect image quality. Moreover, the fixing unit may become dirty, or the paper could jam, and a service repair may be needed.
You cannot select [Sheets] and [Chapter Pages] at the same time.
If you want to select [Tab], load the tab paper in the Multi-Purpose Tray or Paper Drawer 2. Select [Tab] on the Select Paper screen → press [Number of Tabs]. Specify the number of tabs → press [OK].
(numeric keys).|
If you set a different paper size for the front cover, back cover, or sheet insertions, the paper sizes for the other features are automatically changed to the new paper size. However, changing the paper source for a feature to a source with the same paper size does not change the settings for the other features.
If you select [Tab], only LTR paper can be used.
You can insert sheets and chapter pages starting from page 2.
If [Print on Both Sides] is selected for the front cover in [Add Cover] and tab paper is set to insert in front of the first page, the front cover is output first, and then the tab paper is output. The front cover outputs as a blank paper and prints are made starting from the tab paper.
If you select [Leave Blank] for the sheet insertion, you can set the same page for tab paper. In this case, the paper for the sheet insertion is output first, and then the tab paper is output.
You can insert a total of up to 100 sheet insertions or chapter pages.
If you are using paper that already has printing on it (e.g., company logo) as your sheet insertion, then you must select [Leave Blank]. Otherwise, the machine will print on the preprinted paper.
You can confirm/change the settings for sheet insertions, chapter pages, tab paper by pressing [Details/Edit] after selecting the settings.
To delete a sheet insertion, select the setting to delete → press [Delete].
Make sure that the Number of Tabs shown on the touch panel display is the same as the number of tabs on the tab paper loaded in the multi-purpose tray.
If [Staple] is selected, for the total number of sheets that can be stapled, including sheet insertions and chapter pages, see "Maximum number of sheets you can staple."
You cannot select multiple files and specify sheet insertion settings for the files at the same time. In this case, set the Job Separator mode. (See "Job Separator.")
If you are printing on the sheet insertions, these sheets are included in the count of the total number of prints made. However, if these sheets are left blank, the machine's counter does not count them as prints.
If you add chapter pages, these sheets are included in the count of the total number of prints made.
If you want to set both [Insert Sheets] and [Add Cover], select the same paper size.
Tab paper is always printed on. If you do not want to print on the tab paper, insert blank sheets of paper in each place where you want the tab paper to go.
When printing on tab paper, check that the position of the tabs is correct.
If [Unfinished Tab Paper Forced Output] in [Function Settings] (Settings/Registration) is set to 'On', the extra amount of tab paper sheets that were not required for the job are forced out of the machine.
Example: If the number of tabs is set to 5 and the machine estimates that seven sheets of tab paper are needed for the print job, you must prepare two sets of tab paper each containing five tabs (10 total). Therefore, if the machine only uses seven tab paper sheets, three tab paper sheets will remain.
Areas of images shifted outside the tab paper cannot be printed on the paper, and may cause the following prints to have black streaks or appear dirty.
