Top » Copy » Interrupt Mode
Interrupt Mode
06RH-0L4
The interrupt mode enables you to pause a reserved or current job to make higher priority copies. This mode is useful if you need to make a rush copy during a long copy job.
Press [Copy].
Press [Interrupt].
To change the Department ID before copying, press (Log In/Out) → enter the Department ID and PIN using - (numeric keys). (See "Entering the Department ID and PIN.")
Pressing [Interrupt] does not immediately stop the current job. Printing of the current job stops only when the actual printing of the priority or interrupt copy starts.
Set the desired copy modes.
4.
Press (Start).
If you want to continue making interrupt copies, wait until the current interrupt copy job is complete. Then, repeat steps 2 to 3.
You cannot make interrupt copies if there is an interrupt copy job being processed or waiting to be processed.
To cancel the interrupt mode, press [Interrupt].
