If you are copying onto the back side of a previously printed sheet, load the paper as indicated below.
Paper drawer: Load the side to copy on face up.
Multi-purpose tray, Paper Deck Unit-B2: Load the side to copy on face down.
Other Settings
Example of Stapling Position
Corner: Top Right
Double: Right ![]() LTR, EXEC
Corner: Top Right
Double: Top ![]() 11" x 17", LGL, LTRR
Corner: Top Right
![]() LTR, EXEC
Corner: Top Right
Double: Right ![]() 11" x 17", LGL, LTRR
Preprinted paper
Loading location: Paper drawer
Preprinted paper: Face up |
Loading location: Multi-purpose tray
Preprinted paper: Face down |
Loading location: Paper Deck Unit-B2
Original
Loading location: Platen glass
Original: Face down |
Stapling setting
Corner: Top Right
Double: Right |
Corner: Bottom Right
Double: Right |
Corner: Top Right
Corner: Top Right
Double: Right |
Loading location: Feeder
Original: Face up |
Stapling setting
Corner: Top Right
Double: Right |
Double: Right |
Corner: Top Right
Corner: Top Right
Double: Right |
Auto Rotation Setting
Both ON and OFF available
Both ON and OFF available (ON when
loaded vertically in the multi-purpose tray or vertically in a paper drawer) |
Other Settings
Corner: Top Left
Double: Left
![]() LTR, EXEC
Corner: Top Left
Corner: Top Left
![]() LTR, EXEC
Corner: Top Left
Double: Left ![]() 11" x 17", LGL, LTRR
Preprinted paper
Original
Stapling setting
Corner: Top Left
Double: Left |
Corner: Top Right
Double: Right |
Corner: Top Left
Corner: Top Left
Double: Left |
Original: Face up |
Stapling setting
Corner: Top Left
Double: Left |
Corner: Top Right
Double: Right |
Corner: Top Left
Corner: Top Left
Double: Left |
(ON when
Other Settings
Example Output
![]() LTR, EXEC
![]() LTR, LTRR, EXEC
Preprinted paper
Original
Original: Face down
Original: Face up
(ON when
Function
Functions that Cannot Be Used in Combination
Preset Zoom
Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, Auto Zoom*1, Set by Length*1, Poster (Number of Output Pages)*1, Poster (%)*1, N on 1*1, Booklet Scanning*1, Divided Booklet*1, Creep Correction*1
Zoom by Percentage
Preset Zoom*1, XY Independent*1, Auto XY Ratio*1, Auto Zoom*1, Set by Length*1, Poster (Number of Output Pages)*1, Poster (%)*1, N on 1*1, Booklet Scanning*1, Divided Booklet*1, Creep Correction*1
XY Independent
Preset Zoom*1, Zoom by Percentage*1, Auto XY Ratio*1, Auto Zoom*1, Set by Length*1, Poster (Number of Output Pages)*1, Poster (%)*1, N on 1*1, Booklet Scanning*1, Divided Booklet*1, Creep Correction*1
Auto XY Ratio
Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Auto Zoom*1, Set by Length*1, Automatic Paper Selection, Poster (Number of Output Pages)*1, Poster (%)*1, N on 1*1, Repeat Images (Auto), Repeat Images (Auto) + Framing, Booklet Scanning*1, Between Batches, Print on Tab, Tab Paper, Divided Booklet*1, Creep Correction*1
Auto Zoom
Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, Set by Length*1, Automatic Paper Selection, Poster (Number of Output Pages)*1, Poster (%)*1, Repeat Images (Auto), Repeat Images (Auto) + Framing, Between Batches, Print on Tab, Tab Paper
Set by Length
Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, Auto Zoom*1, Poster (Number of Output Pages)*1, Poster (%)*1, Print on Tab, Tab Paper
Fit to Page
Poster (Number of Output Pages), Poster (%), N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Booklet Scanning, Do Not Booklet Scan, Between Batches, Print on Tab, Tab Paper, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction
Function
Manual Paper Selection*1, Custom Size*1, Poster (Number of Output Pages)*1, N on 1*1, Booklet Scanning*1, Do Not Booklet Scan*1, Between Batches, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Saddle Stitch*1, Saddle Fold*1, Print on Tab*1, Divided Booklet*1, Creep Correction*1
Automatic Paper Selection*1, Custom Size*1, Between Batches, Print on Tab*1
Custom Size
Automatic Paper Selection*1, Manual Paper Selection*1, 1-Sided
Scanning Originals Loaded in the Feeder
Book
Function
Collate
Poster (Number of Output Pages)*1, Poster (%)*1, Transparency Cover Sheets*1, Booklet Scanning*1, Do Not Booklet Scan, Between Batches, Group*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Offset Group*1, Staple*1, Saddle Stitch*1, Divided Booklet*1, Creep Correction*1
Group
Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Offset Group*1, Staple*1, Saddle Stitch*1, Saddle Fold, Print on Tab, Tab Paper, Copy Sample, Copy Set Numbering, Divided Booklet, Creep Correction, Merge Job Blocks, Secure Watermark*2
Automatic Paper Selection, Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Group*1, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Hole Punch, Print on Tab, Tab Paper, Divided Booklet, Creep Correction, Merge Job Blocks
Automatic Paper Selection, Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Collating*1, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Hole Punch, Print on Tab, Tab Paper, Copy Sample, Copy Set Numbering, Divided Booklet, Creep Correction, Merge Job Blocks, Secure Watermark*2
Offset Collate
Poster (Number of Output Pages)*1, Poster (%)*1, Transparency Cover Sheets*1, Booklet Scanning*1, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group*1, Offset Group, Staple*1, Saddle Stitch*1, Saddle Fold, Print on Tab, Divided Booklet*1, Creep Correction*1
Offset Group
Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate*1, Staple*1, Saddle Stitch*1, Saddle Fold, Print on Tab, Tab Paper, Copy Sample, Copy Set Numbering, Divided Booklet, Creep Correction, Merge Job Blocks, Secure Watermark*2
Staple
Poster (Number of Output Pages), Poster (%), Mirror Image, Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Saddle Stitch*1, Saddle Fold, Print on Tab, Divided Booklet, Creep Correction
Saddle Stitch
Automatic Paper Selection, Book
Function
Saddle Fold
Hole Punch
Custom Size, Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Saddle Stitch, Saddle Fold, Print on Tab, Divided Booklet, Creep Correction
Function
1-Sided
Custom Size, Book
Book
Custom Size, 1-Sided
2-Sided
2-Sided
1-Sided
Auto (Color/Black), Background Density (Auto), Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, Auto Zoom*1, Set by Length*1, Fit to Page, Automatic Paper Selection, Custom Size, 1-Sided
Poster (%)
Auto (Color/Black), Background Density (Auto), Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, Auto Zoom*1, Set by Length*1, Fit to Page, Custom Size, 1-Sided
Book
N on 1
Fit to Page, Automatic Paper Selection, Custom Size, Book
Fit to Page, Poster (Number of Output Pages), Poster (%), N on 1, Erase Book Frame*1, Erase Binding*1, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Booklet Scanning, Do Not Booklet Scan, Between Batches, Print on Tab, Tab Paper, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction
Erase Book Frame
Fit to Page, Poster (Number of Output Pages), Poster (%), N on 1, Erase Original Frame*1, Erase Binding*1, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Booklet Scanning, Do Not Booklet Scan, Between Batches, Print on Tab, Tab Paper, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction
Erase Binding
Fit to Page, Book
Interrupt
Between Batches, Merge Job Blocks
Function
Shift (By Position)
Poster (Number of Output Pages), Poster (%), Shift (By Numeric Keys)*1, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Between Batches, Print on Tab, Tab Paper
Poster (Number of Output Pages), Poster (%), N on 1, Shift (By Position)*1, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Booklet Scanning, Do Not Booklet Scan, Between Batches, Print on Tab, Tab Paper, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction
Gutter
Poster (Number of Output Pages), Poster (%), Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Booklet Scanning, Do Not Booklet Scan, Between Batches, Print on Tab, Tab Paper, Divided Booklet, Creep Correction, Scan Lock Information (TL Code)
1-Sided
Front Cover
Book
Book
Tab Paper
Auto XY Ratio, Auto Zoom, Set by Length, Fit to Page, Book
Function
Booklet Scanning
Do Not Booklet Scan
Divided Booklet
Creep Correction
Function
Sharpness
Between Batches, Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Nega/Posi
Between Batches, Color Balance (Adjust Black Hue), Merge Job Blocks, Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Mirror Image
Fit to Page, Poster (Number of Output Pages), Poster (%), N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Staple, Saddle Stitch, Saddle Fold, Tab Paper, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy upon Storing), Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Repeat Images
Fit to Page, Book
Auto XY Ratio, Auto Zoom, Fit to Page, Automatic Paper Selection, Book
Fit to Page, Book
Framing
Book
Blanking
Book
Job Build
Poster (Number of Output Pages), Poster (%), Between Batches, Merge Job Blocks
Between Batches
Background Density (Adjust All Color), Auto XY Ratio, Auto Zoom, Fit to Page, Automatic Paper Selection, Manual Paper Selection, Custom Size, Book
Different Size Originals
Book
Copy Sample
Poster (Number of Output Pages), Poster (%), Between Batches, Group*1, Rotate 90 Degrees: Group*1, Offset Group*1, Store in Mail Box
Superimpose Image
Adjust One-Touch Color (Sepia Tone), Poster (Number of Output Pages), Poster (%), N on 1, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Saddle Stitch, Saddle Fold, Tab Paper, Page Numbering, Copy Set Numbering, Watermark, Print Date, Two Colors, Divided Booklet, Creep Correction, Print & Check, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy upon Storing), Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Function
Print on Tab
Auto XY Ratio, Auto Zoom, Set by Length, Fit to Page, Automatic Paper Selection, Manual Paper Selection, 1-Sided
Page Numbering
Fit to Page, Adjust One-Touch Color (Sepia Tone), Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Transparency Cover Sheets, Front Cover*3, Sheets/Chapter Pages*3, Do Not Booklet Scan, Between Batches, Saddle Stitch, Saddle Fold, Print on Tab, Superimpose Image, Copy Set Numbering*5, Watermark*5, Print Date*5, Two Colors
Copy Set Numbering
Fit to Page, Adjust One-Touch Color (Sepia Tone), Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Transparency Cover Sheets, Front Cover*3, Sheets/Chapter Pages*3, Do Not Booklet Scan, Between Batches, Group, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Saddle Fold, Print on Tab, Superimpose Image, Page Numbering*5, Watermark*5, Print Date*5, Two Colors, Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Watermark
Fit to Page, Adjust One-Touch Color (Sepia Tone), Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Transparency Cover Sheets, Front Cover*3, Sheets/Chapter Pages*3, Booklet Scanning, Do Not Booklet Scan, Between Batches, Saddle Stitch, Saddle Fold, Print on Tab, Superimpose Image, Page Numbering*5, Copy Set Numbering*5, Print Date*5, Two Colors, Divided Booklet, Creep Correction, Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Print Date
Fit to Page, Adjust One-Touch Color (Sepia Tone), Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Transparency Cover Sheets, Front Cover*3, Sheets/Chapter Pages*3, Booklet Scanning, Do Not Booklet Scan, Between Batches, Saddle Stitch, Saddle Fold, Print on Tab, Superimpose Image, Page Numbering*5, Copy Set Numbering*5, Watermark*5, Two Colors, Divided Booklet, Creep Correction, Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Print & Check
Book
Merge Job Blocks
Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Poster (Number of Output Pages), Poster (%), Single Color, Nega/Posi, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Between Batches, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Saddle Fold, Print on Tab, Interrupt, Superimpose Image, Two Colors, Divided Booklet, Creep Correction, Print & Check, Color Balance (Adjust Hue), Color Balance (Adjust Saturation), Color Balance (Adjust Black Hue), Secure Watermark*6, Scan Lock Information (QR Code)*6, Scan Lock Information (TL Code)*6, Tracking Information*6
Store in Mail Box
Custom Size, Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Single Color, Mirror Image, Between Batches, Copy Sample, Superimpose Image, Two Colors, Print & Check, Color Balance (Adjust Hue), Color Balance (Adjust Saturation), Color Balance (Adjust Black Hue)
Custom Size, Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Single Color, Mirror Image, Between Batches, Superimpose Image, Two Colors, Color Balance (Adjust Hue), Color Balance (Adjust Saturation), Color Balance (Adjust Black Hue)
Secure Watermark
Sharpness, Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Single Color, Nega/Posi, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Booklet Scanning, Do Not Booklet Scan, Between Batches, Group*2, Rotate 90 Degrees: Group*2, Offset Group*2, Superimpose Image, Copy Set Numbering, Watermark, Print Date, Two Colors, Divided Booklet, Creep Correction, Color Balance (Adjust Hue), Color Balance (Adjust Saturation), Color Balance (Adjust Black Hue), Merge Job Blocks*6, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Sharpness, Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Single Color, Nega/Posi, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Booklet Scanning, Do Not Booklet Scan, Between Batches, Superimpose Image, Copy Set Numbering, Watermark, Print Date, Two Colors, Divided Booklet, Creep Correction, Color Balance (Adjust Hue), Color Balance (Adjust Saturation), Color Balance (Adjust Black Hue), Merge Job Blocks*6, Scan Lock Information (TL Code), Tracking Information
Sharpness, Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Single Color, Nega/Posi, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Booklet Scanning, Do Not Booklet Scan, Between Batches, Superimpose Image, Copy Set Numbering, Watermark, Print Date, Two Colors, Divided Booklet, Creep Correction, Color Balance (Adjust Hue), Color Balance (Adjust Saturation), Color Balance (Adjust Black Hue), Merge Job Blocks*6, Secure Watermark, Scan Lock Information (QR Code)
Tracking Information (Scan Lock Information: TL Code)
Function
Auto (Color/Black)
Full Color*1, Black*1, Adjust One-Touch Color (Sepia Tone)*1, Single Color*1, Two Colors*1
Full Color
Auto (Color/Black)*1, Black*1, Adjust One-Touch Color (Sepia Tone)*1, Single Color*1, Two Colors*1
Black
Auto (Color/Black)*1, Full Color*1, Adjust One-Touch Color (Sepia Tone)*1, Single Color*1, Two Colors*1
Background Density (Adjust Each Color)*1, Background Density (Adjust All Color)*1, Poster (Number of Output Pages), Poster (%)
Background Density (Auto)*1, Background Density (Adjust All Color)*1
Background Density (Auto)*1, Background Density (Adjust Each Color)*1, Between Batches
Between Batches, Color Balance (Adjust Hue), Color Balance (Adjust Saturation), Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy upon Storing), Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Color Balance*1, Color Balance (Fine Adjust Density)*1, Between Batches, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy upon Storing), Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Auto (Color/Black)*1, Full Color*1, Black*1, Single Color, Between Batches, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Two Colors, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy upon Storing), Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Color Balance
Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction)*1, Between Batches, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy upon Storing), Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Single Color
Auto (Color/Black)*1, Full Color*1, Black*1, Adjust One-Touch Color (Sepia Tone), Two Colors*1, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy upon Storing), Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Two Colors
Auto (Color/Black)*1, Full Color*1, Black*1, Adjust One-Touch Color (Sepia Tone), Single Color*1, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy upon Storing), Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Between Batches, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy upon Storing), Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Nega/Posi, Between Batches, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy upon Storing), Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code)*6, Tracking Information
