Top » Copy » Changing and Canceling Copy Settings
06RH-0L3
You can use the Setting Confirmation screen to confirm, change, or cancel selected copy modes.
Press [Copy].
Set the desired copy modes → press [Check Settings].
You can check the settings.
A right triangle () displayed on the [Change] button when a copy mode is selected indicates that more setting screens are available by pressing the key.
Change or cancel the selected copy mode.
Changing the copy mode:
Canceling the copy mode:
Select the desired mode.
Press [Change] → change the settings.
Change the settings as required, using the same procedure as for setting each mode.
Press [Change] → cancel the settings.
To cancel a mode that does not have a setting screen, press [Change].
4.
Press [OK].
