To cancel scanning, press [Cancel] or
If you place your originals in the feeder, remove the originals from the original output area when the scanning of each batch is complete.
You can change only those settings appearing in [Change Settings] while in the Job Build mode. You need to specify the necessary copy settings in advance. However, if you specify [N on 1] with the Job Build mode, you cannot change the settings for [Density] or [Select Color].
You can change or specify the following settings before scanning the next batch of originals (i.e., between batches): the number of copies, 2-Sided Original mode, original type, and copy exposure. However, if you specify the Image Combination mode together with the Job Build mode, you cannot change the copy exposure and original type.
If you want to place different size originals in the feeder, set [Different Size Originals]. (See "Different Size Originals.")
When you want to copy one-sided and two-sided originals as two-sided copies, set [1-Sided
