Be sure to correctly set the paper type. If the type of paper is not set correctly, it may adversely affect image quality. Moreover, the fixing unit may become dirty, or the paper could jam, and a service repair may be needed.
The Finishing modes cannot be set if Custom Size, envelopes, transparencies, tracing paper, or labels is selected.
The paper used for the cover page must be the same size as that which is used for the main document.
Only 14 lb bond to 80 lb cover (52 to 220 g/m2) paper can be used for the main document.
Only 14 lb bond to 140 lb index (52 to 256 g/m2) paper can be used for the cover page.
The accuracy of folds created in the Saddle Stitch mode may vary, depending on the paper type and the number of sheets.
To use the Saddle Stitch mode, the original must already be in booklet form, as shown in the illustration above. (See "Booklet Mode.")
[Saddle Fold] can only be set when two-sided copying is set.
The paper is saddle folded one sheet at a time, and then output.
You can only set [Rotate 90 Degrees] in the following cases:
If you select the available paper size manually
If the paper size compatible with Rotate 90 Degrees is loaded in both the horizontal and vertical directions
If [Paper Drawer Auto Selection On/Off] for the selected paper source is set to 'On' (See "Enabling Paper Drawer Auto Selection.")
If there is no paper which can be rotated, the output is collated.
: Available|
Optional Unit
Collate
(Page Order) |
Group
(Same Pages)
Offset
Rotate 90 Degrees
Staple
Hole Punch
Saddle Fold
Corner
Double
Saddle Stitch
None
Copy Tray-J1
Inner Finisher-E1
Inner 2 Way Tray-F1
Inner 2 Way Tray-F1 and Copy Tray-J1
Staple Finisher-J1
Staple Finisher-J1 and Puncher
Booklet Finisher-J1
Booklet Finisher-J1 and Puncher
Paper Size
Corner
Double
Saddle Stitch*
12" x 18"
16 sheets
12 5/8" x 17 11/16"
11" x 17"
30 sheets
30 sheets
16 sheets
LGL
30 sheets
30 sheets
16 sheets
LTRR
30 sheets
30 sheets
16 sheets
LTR
50 sheets
50 sheets
EXEC
50 sheets
50 sheets
STMTR
STMT
For information on the original orientation and paper orientation when performing stapling, see "Relationship Between the Original Orientation and Paper Orientation."
For information on optional products, see the following:
If [Finishing] is not set, sheets are output in the same way as when [Group (Same Pages)] is set.
If [Auto Collate] is set to 'On', the Collate or Offset Collate mode is automatically set when you place your originals in the feeder. (See "Enabling Auto Collating.")
You can display the detailed information of the selected paper by pressing
