Top » Copy » Area Designation
Area Designation
06RH-0RS
This mode enables you to frame areas to scan/copy, or areas to blank out in the scanned image. You can designate up to four areas using the edit pen on the preview screen, or the numeric keys on the control panel. You can designate up to four different areas.
To use Area Designation (Framing) with the Image Repeat mode, first specify the Image Repeat mode, and then designate the desired area. Only one area can be designated.
The designated area is too small, the color original may be scanned in the Black mode even if the color mode is set to 'Auto (Color/Black)'.
You can use the numeric keys to modify areas designated with the edit pen.
If you designate an area using the edit pen, the output image may not reflect the designated area precisely. To designate an area precisely, enter the values using the numeric keys.
Using the Edit Pen
You can use the edit pen to designate two different types of areas: a rectangular area (two points) and a polygonal area (four points or more).
Use two points to designate the area
Use multiple points to designate the area
You can designate only one polygonal area at a time.
You cannot designate a rectangular area and a polygonal area at the same time.
You cannot copy or scan documents with the Area Designation mode if you place your originals in the feeder.
Press [Copy].
Press [Options] → [Area Designation].
Press [Pen Entry].
4.
Press [Start Scanning].
Confirm that the original is placed on the platen glass.
5.
Designate the area using the edit pen.
To clear the last point entered, press [Delete Point]. (Once an area is designated, [Delete Point] changes to [Clear Area].)
To clear a designated area, press [Clear Area].
To zoom in on any area on the original, press the ratio drop-down list → select an enlargement ratio → press [], [], [], or [] to display the desired area.
To designate a rectangular area with two points:
To designate an area with multiple points:
Designate two opposing points with the edit pen.
Press [Enter Multipoints] → specify the area with the edit pen.
After designating the last point, press [Set Multipoints].
You can designate up to 10 points.
If you select [Enter Multipoints], only one area can be designated at a time.
An area that is designated by selecting [Enter Multipoints], cannot be modified using - (numeric keys).
6.
Select [Framing] or [Blanking].
Details of each item are shown below.
[Framing]:
Copy only the contents of the designated area while discarding the rest of the original.
[Blanking]:
Copy the original by blanking out the contents of the designated area.
If you want to use different settings for different areas, select the area by pressing the appropriate area key → select [Framing] or [Blanking].
7.
Press [Preview] → check the designated area → press [OK].
If the designated area is rectangular, and you want to continue designating other areas, repeat steps 3 to 5. Areas that have already been designated are displayed with the new area.
To modify a designated area that was specified using the edit pen, press [Fine Adjust] → [Select Point] until the screen displays the desired point that you want to modify → press [], [], [], or [] to move the point → press [OK] → [Preview] to check the modified area.
8.
Press [Next] → select [Center Shift] or [Do Not Center Shift].
If only [Blanking] is selected, this step is unnecessary. Skip to step 8.
If the Center Shift mode is already specified beforehand, the Center Shift Settings screen does not appear.
The Center Shift settings specified within the Area Designation mode are deleted when the area settings are canceled.
9.
Press [OK].
If you need to designate the same area for multiple originals, remove the original from the platen glass → place all of the originals in the feeder → press (Start).
Using the Numeric Keys
For instructions on entering values in inches, see "Basic Operations."
Press [Copy].
Press [Numeric Key Entry].
Before performing the next step, you must manually measure the size and position of the area that you want to designate on the original.
When you measure the XY values, always start measuring from the image out to the right side edge of the original, and up to the top of the original. These measurements tell the machine the desired framed area's size and position.
4.
Press [X1], [X2], [Y1], and [Y2] → use - (numeric keys).
[X1]:
The distance of the area's right border to the original's right edge.
[X2]:
The distance of the area's left border to the original's right edge.
[Y1]:
The distance of the area's top border to the original's top edge.
[Y2]:
The distance of the area's bottom border to the original's top edge.
You can designate up to four areas.
To change a value you entered, press [X1], [X2], [Y1], or [Y2] → enter the correct value using - (numeric keys).
To check the designated area, press [Check Area].
5.
[Framing]:
[Blanking]:
To continue designating other areas, press an area key → repeat step 3.
To redesignate an area, select the area by pressing the appropriate area key.
To clear a designated area, select the area by pressing the appropriate area key → press [Clear Area].
6.
If only [Blanking] is selected, this step is unnecessary. Skip to step 6.
7.
Press [OK].
