LTR is the only paper size available for the Transparency Cover Sheets mode.
Even if a finisher is attached, you cannot use any of the modes in [Finishing] with [Transparency Cover Sheets].
If Tray Designation settings are set only for Copy Tray-J1, transparencies are output to Tray A. The Tray Designation settings may vary depending on the optional output units that are attached to the machine. For details on the tray designations, see "Output Tray Designation."
The copies are output with the copied side face down, alternating between transparency and interleaf sheet.
In the Transparency Cover Sheets mode, transparencies are loaded from the multi-purpose tray while interleaf sheets are loaded from a paper drawer.
