Top » Copy » Storing, Recalling, and Deleting Favorite Settings (Favorite Settings)
06RH-0KY
You can store up to nine combinations of copy settings in memory keys. You can also set easy to remember names for each.
It is convenient to store frequently used combinations of settings in this way.
The copy settings registered as [Favorite Settings] in memory are not deleted, even if you turn the main power OFF.
You can also store/edit favorite settings by pressing → [Register/Edit Favorite Settings].
You can also register favorite settings in the shortcut keys. (See "Assigning Shortcuts.")
