e-Manual
Top
Site map
Help
Glossary
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products/Software
Settings/Registration
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Web Access
Scanner
Quick Menu
Status Monitor/Cancel
Print
Network
Remote UI
MEAP
Security
Practical Workflows
How to Use This Manual
Expand All
Collapse All
Category Top
Overview of This Function
Flow of Copy Operations
Canceling a Copy Job
Reserved Copying
Changing Color Modes
Copy Sample
Recalling Previous Copy Jobs (Previous Settings)
Storing, Recalling, and Deleting Favorite Settings (Favorite Settings)
Storing Favorite Settings
Recalling and Deleting Favorite Settings
Assigning Shortcuts
Changing and Canceling Copy Settings
Interrupt Mode
Changing Basic Copy Ratios
Zoom by Length
Setting the X and Y Axes Independently
Poster
Paper Selection
Book→2 Pages
Two-Sided Copying
Collating Copies
Booklet Mode
Job Build
N on 1
Add Cover
Inserting Sheets
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Selecting the Original Type
Inserting Sheets When Copying Onto Transparencies
Adding a Secure Watermark
Document Scan Lock
Document Scan Lock (TL Code)
Document Scan Lock (QR Code)
Adjusting the Color
One Touch Color Mode
Page Numbering
Copy Set Numbering
Adjusting the Image Sharpness
Erase Frame
Watermark Printing
Date Printing
Shifting the Original Image
Gutter Mode
Print & Check
Inverting Images (Nega/Posi)
Repeat Images
Merge Job Blocks
Job Done Notice
Mirror Image
Area Designation
Print on Tab
Store in Mail Box
Superimpose Image
Various Features of the Express Copy Basic Features Screen
Operating the Express Copy Basic Features Screen
Setting Shortcuts on the Express Copy Basic Features Screen
Appendix
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Web Access
Scanner
Quick Menu
Print
Network
Remote UI
MEAP
Security
Practical Workflows
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
Copy
Mirror Image
Mirror Image
06RH-0RR
This mode enables you to copy the original image reversed, as if it were a reflection in a mirror.
Press [Copy].
Press [Options] → [Mirror Image] → [Close].
For information on the modes which cannot be set in combination with this mode, see
"Unavailable Combination of Functions."
Back to Top
