Troubleshooting for AirPrint
0UKW-0SF
Check the followings if you cannot print with AirPrint.
Make sure that the machine is turned ON. If the machine has already been turned ON, turn the machine OFF and then ON again after 10 seconds to see whether this fixes the problem.
(See "Main Power and Energy Saver Key.")
Make sure that the Apple device (iPad/iPhone/iPod touch/Mac) and the machine are connected to the same LAN. It may take several minutes until the machine is ready to communicate after its power is turned ON.
Make sure that Bonjour is enabled on the Apple device.
