e-ManualTopSite mapHelp
Category Top
Printing Functions
[Basic Settings] Tab
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Printing Fundamentals
Printing
Viewing Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing from a Computer (Mac OS)
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Viewing Help
Scaling Documents
Setting Custom Paper Sizes
Using [Presets] for Printing
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Print Quality
Layout
Auto Error Skip
Secure Print Delete Time
Timeout
Finishing
Copy Set Numbering
Personality
Mode Priority
Color Mode
Gradation Settings
Compressed Image Output
Initialize
UFR II Settings
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
CMS (Matching) Selection
CMS (Matching)/Gamma
Gamma Correction
Paper Save
Advanced Smoothing
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code (Symbol Set)
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
Gamma Correction
Advanced Smoothing
PS Settings
Job Timeout
Print PS Errors
Pure Black Text
Black Overprint
RGB Source Profile
CMYK Simulation Profile
Use Grayscale Profile
Output Profile
Matching Method
RGB Pure Black Process
CMYK Pure Black Process
Halftones
Brightness
Composite Overprint
Advanced Smoothing
Grayscale Conversion
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
ICC Profile Settings
Photo Correct. (Color Only)
Halftones
Gray Compensation
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Pure Black Text
Black Overprint
RGB Source Profile
Output Profile
Matching Method
Halftones
Brightness
Composite Overprint
Advanced Smoothing
XPS Settings
Matching Mode
Gamma Correction
Photo Correct.(Color Only)
Halftones
Gray Compensation
Advanced Smoothing
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
AirPrint
What Is AirPrint?
Before Printing
Printing Using AirPrint
Canceling AirPrint Printing
Using the AirPrint Portal Page
Configuring the Settings for Printing Using SSL and Authentication
Requesting Certificate Signing
Troubleshooting for AirPrint
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Top » Print » AirPrint » Before Printing
Before Printing
0UKW-0S7
The settings required for using AirPrint can be configured remotely using the Remote UI. It is necessary to log in with administrator privileges to configure the settings.
Configuring Settings Using the Remote UI
Start the Web browser and log in as an administrator.
http://<IP address or host name of the machine>/
For more information, see "Remote UI."
Click [Settings/Registration] → select [Network Settings] in <Preferences> → click [AirPrint Settings].
If you are using a mobile device, such as an iPad, iPhone, or iPod touch, read "click" as "tap" in this section.
Specify the required settings → click [OK].
[Use AirPrint]:
Select this check box.
[Printer Name]:
Enter the name of the machine. If an mDNS name has already been registered in [mDNS Settings] ([Network] in [Preferences] (Settings/Registration)), the registered name is displayed.
[Location]:
Enter the location of the machine. If a location has already been registered in [Device Information Settings] ([Device Management] in [Management Settings] (Settings/Registration)), the registered name is displayed.
[Latitude]:
Enter the latitude of the location where the machine is installed.
[Longitude]:
Enter the longitude of the location where the machine is installed.
[Auto Acquire]:
Automatically sets the latitude and longitude of the location where the machine is installed.
If you select [Use AirPrint], the following settings are enabled.
[Settings/Registration] → [Network Settings] in <Preferences> → [HTTP Settings] → [Use HTTP]
[Settings/Registration] → [Network Settings] in <Preferences> → [IPP Print Settings] → [Use IPP]
[Settings/Registration] → [Network Settings] in <Preferences> → [IPv4 Settings] → [Use mDNS]
[Settings/Registration] → [Network Settings] in <Preferences> → [IPv6 Settings] → [Use mDNS]
If you change a printer name that has been previously set, you may become unable to print from a Mac. This is because the mDNS name used for IPv4/IPv6 is changed. In this case, add the machine to the Mac again.
Entering the printer name makes it easier to identify multiple printers that support AirPrint.
Configuring Settings from the Touch Panel Display
Press [Log In] → enter the System Manager ID and System Manager PIN → press (Log In/Out).
Press [Preferences] → [Network] → [Use AirPrint].
4.
Press [On] → [OK].
If you press [On], the following settings are enabled.
[Preferences] (Settings/Registration) → [Network] → [TCP/IP Settings] → [Use HTTP]
[Preferences] (Settings/Registration) → [Network] → [TCP/IP Settings] → [IPP Print Settings]
[Preferences] (Settings/Registration) → [Network] → [TCP/IP Settings] → [DNS Settings] → [mDNS Settings] → [Use IPv4 mDNS]
[Preferences] (Settings/Registration) → [Network] → [TCP/IP Settings] → [DNS Settings] → [mDNS Settings] → [Use IPv6 mDNS]
5.
Press [Device Position Information Settings] → specify the latitude and longitude of the machine → press [OK].
The printer name and location can be checked by following the procedures below.
To check the printer name, see the value for the mDNS name in [mDNS Settings] ([Network] in [Preferences] (Settings/Registration)).
To check the location, see the value for the location in [Device Information Settings] ([Device Management] in [Management Settings] (Settings/Registration)).
