e-ManualTopSite mapHelp
Category Top
Printing Functions
[Basic Settings] Tab
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Printing Fundamentals
Printing
Viewing Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing from a Computer (Mac OS)
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Viewing Help
Scaling Documents
Setting Custom Paper Sizes
Using [Presets] for Printing
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Print Quality
Layout
Auto Error Skip
Secure Print Delete Time
Timeout
Finishing
Copy Set Numbering
Personality
Mode Priority
Color Mode
Gradation Settings
Compressed Image Output
Initialize
UFR II Settings
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
CMS (Matching) Selection
CMS (Matching)/Gamma
Gamma Correction
Paper Save
Advanced Smoothing
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code (Symbol Set)
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
Gamma Correction
Advanced Smoothing
PS Settings
Job Timeout
Print PS Errors
Pure Black Text
Black Overprint
RGB Source Profile
CMYK Simulation Profile
Use Grayscale Profile
Output Profile
Matching Method
RGB Pure Black Process
CMYK Pure Black Process
Halftones
Brightness
Composite Overprint
Advanced Smoothing
Grayscale Conversion
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
ICC Profile Settings
Photo Correct. (Color Only)
Halftones
Gray Compensation
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Pure Black Text
Black Overprint
RGB Source Profile
Output Profile
Matching Method
Halftones
Brightness
Composite Overprint
Advanced Smoothing
XPS Settings
Matching Mode
Gamma Correction
Photo Correct.(Color Only)
Halftones
Gray Compensation
Advanced Smoothing
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
AirPrint
What Is AirPrint?
Before Printing
Printing Using AirPrint
Canceling AirPrint Printing
Using the AirPrint Portal Page
Configuring the Settings for Printing Using SSL and Authentication
Requesting Certificate Signing
Troubleshooting for AirPrint
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Top » Print » Setting the Machine (PS/PCL/UFR II Printer) » Settings Menu (Common Settings) » Print Quality
Print Quality
0UKW-0H3
Density
[Cyan]
-8 to +8; 0*
[Magenta]
-8 to +8; 0*
[Yellow]
-8 to +8; 0*
[Black]
-8 to +8; 0*
This mode is not available if you set [Toner Save] to [On].
This setting adjusts the print density.
Pressing [Dark] makes the print image darker, pressing [Light] makes the image lighter.
Density (Fine Adjust)
[Cyan]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
[Magenta]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
[Yellow]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
[Black]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
This setting adjusts the print density of the respective colors.
Toner Save
[On], [Off]*
This setting enables you to set the Toner Save mode. Toner Save uses less toner to print documents and may result in longer toner life.
Gradation
[High 1]*, [High 2]
[High 1]: Creates four-color gradation data (2 bit/pixel)
[High 2]: Creates 16-color gradation data (4 bit/pixel)
Sharpness (Photo)
[On], [Off]
[Low], [Medium]*, [High]
This mode is not available if you set [Sharpness (Photo)] to [Off].
This setting enables you to adjust the image sharpness. The default is 'Medium'. Select [High] to make image outlines clearer than [Medium], and [Low] to make image outlines blurred.
Special Smoothing Mode
[Mode 1]*, [Mode 2], [Mode 3], [Mode 4], [Mode 5], [Mode 6]
This setting specifies the mode for special smoothing processing. Special smoothing processing corrects vertical color misalignment, which enables you to smoothly print characters, lines, diagrams, images (photos), and gradations that have dark colors.
[Mode 1]:
Smoothly prints the edges of characters, lines, and diagrams that have dark colors. Select [Mode 1] to perform printing normally.
[Mode 2]:
Smoothly prints not only the edges of diagrams, but also the halftones inside the diagrams. Set [Mode 2] if large characters and halftones inside fat lines that have dark colors are misaligned and not printed smoothly when printing with [Mode 1] set.
[Mode 3]:
Smoothly prints characters and lines that have dark colors on a halftone background. Set [Mode 3] if large characters and halftones inside fat lines that have dark colors are misaligned, or when the edges of characters and lines that have light colors are uneven, and not printed smoothly when printing with [Mode 1] set.
[Mode 4]:
Smoothly prints the edges of various objects. Set [Mode 4] if the edges of large characters and fat lines that have light colors are uneven and not printed smoothly when printing with [Mode 1] set.
[Mode 5]:
Evenly prints images and halftone objects. Set [Mode 5] if the gradation bands of images and diagrams are uneven or the dithering patterns are uneven when printing with [Mode 1] set.
[Mode 6]:
Evenly prints all objects. Set [Mode 6] if the halftones of the entire image are misaligned and uneven when printing with [Mode 1] set.
If [Error Diffusion] is set in [Halftones], the [Mode 1] to [Mode 4] settings are disabled, and the same processing as [Mode 6] is performed.
Toner Volume Correction
[Normal]*, [Grad. Priority], [Text Priority]
This setting enables you to automatically adjust toner volume to fall within the internal restriction value when the toner volume has exceeded the internal restriction value of the text, line, or other type of data. Under most circumstances, it is preferable to leave this option set to [Normal].
[Normal]
Text and line data are printed with a toner volume that upholds the resolution for text and lines. Other types of data are printed with a toner volume that upholds the color.
[Grad. Priority]
All data is printed with a toner volume that upholds the color.
[Text Priority]
All data is printed with a toner volume that upholds the resolution.
The internal restriction value cannot be changed.
If [Grad. Priority] is selected, characters and lines may bleed.
If [Text Priority] is selected, the color may not match.
Line Control
[Res. Priority]*, [Grad. Priority]
This setting enables you to specify the image processing for lines. Under most circumstances, it is preferable to leave this setting as [Res. Priority].
[Res. Priority]
Image processing is performed that upholds the same resolution as text for lines.
[Grad. Priority]
Image processing is performed that upholds the same color and gradation as graphics for lines.
The Density mode is not available if you set [Toner Save] to [On].
Depending on the data to be printed, the Toner Save mode may not be applied even if you select [On].
If you select [On] for [Toner Save], very light or finely detailed images may not be printed clearly.
The Toner Volume Correction mode can only be applied to jobs in the PS mode and PDF mode.
If you select [Grad. Priority] for [Toner Volume Correction], characters and lines may bleed.
If you select [Text Priority] for [Toner Volume Correction], the color may not match.
