e-ManualTopSite mapHelp
Category Top
Printing Functions
[Basic Settings] Tab
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Printing Fundamentals
Printing
Viewing Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing from a Computer (Mac OS)
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Viewing Help
Scaling Documents
Setting Custom Paper Sizes
Using [Presets] for Printing
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Print Quality
Layout
Auto Error Skip
Secure Print Delete Time
Timeout
Finishing
Copy Set Numbering
Personality
Mode Priority
Color Mode
Gradation Settings
Compressed Image Output
Initialize
UFR II Settings
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
CMS (Matching) Selection
CMS (Matching)/Gamma
Gamma Correction
Paper Save
Advanced Smoothing
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code (Symbol Set)
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
Gamma Correction
Advanced Smoothing
PS Settings
Job Timeout
Print PS Errors
Pure Black Text
Black Overprint
RGB Source Profile
CMYK Simulation Profile
Use Grayscale Profile
Output Profile
Matching Method
RGB Pure Black Process
CMYK Pure Black Process
Halftones
Brightness
Composite Overprint
Advanced Smoothing
Grayscale Conversion
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
ICC Profile Settings
Photo Correct. (Color Only)
Halftones
Gray Compensation
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Pure Black Text
Black Overprint
RGB Source Profile
Output Profile
Matching Method
Halftones
Brightness
Composite Overprint
Advanced Smoothing
XPS Settings
Matching Mode
Gamma Correction
Photo Correct.(Color Only)
Halftones
Gray Compensation
Advanced Smoothing
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
AirPrint
What Is AirPrint?
Before Printing
Printing Using AirPrint
Canceling AirPrint Printing
Using the AirPrint Portal Page
Configuring the Settings for Printing Using SSL and Authentication
Requesting Certificate Signing
Troubleshooting for AirPrint
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Top » Print » Setting the Machine (PS/PCL/UFR II Printer) » UFR II Settings » RGB Source Profile
RGB Source Profile
0UKW-0HR
[Text]: [sRGB]*, [Gamma 1.5], [Gamma 1.8], [Gamma 2.4], [Download Profile]
[Graphics]: [sRGB]*, [Gamma 1.5], [Gamma 1.8], [Gamma 2.4], [Download Profile]
[Image]: [sRGB]*, [Gamma 1.5], [Gamma 1.8], [Gamma 2.4], [Download Profile]
This setting allows you to specify the RGB profile (color data represented using the RGB (Red Green Blue) color model) that is appropriate for the characteristics of your monitor. This setting is applied when printing a document containing color images or graphics made by the RGB color model.
Settings can be applied separately for text, graphics, and image data.
[sRGB]
This setting specifies the industry standard definition for generic Windows computer monitors. If you are using an sRGB compatible monitor, you can print out colors close to how they appear on your monitor.
[Gamma 1.5], [Gamma 1.8], and [Gamma 2.4]
These settings enable you to select the gamma correct level of the RGB data. The higher the value, the darker the printout.
[Download Profile]
You can store up to 100 profiles.
You can also download the profile from imageWARE Enterprise Management Console.
This setting is only applied if 'CMS(Matching)/Gamma' is set to [CMS].
