[Printer Options] is not displayed on applications that do not support AirPrint. In this case, printing cannot be performed.
Number of copies:
Tap [+] or [-] on the right side of [1 copy] to set the number of copies to print.
[Double-sided]:
Tap [On] on the right side of [Double-sided] to specify 2-sided printing.
[Range]:
Tap [All Pages] or specify the range of pages to print when printing a document with multiple pages.
The available settings on [Printer Options] differ depending on the application you are using.
Available paper sizes differ depending on the application you are using.
For information on canceling printing, see "Canceling AirPrint Printing."
To check the print status, press the Home button of the Apple device twice while printing.
[Presets]:
Specify the print settings by selecting a preset setting from the drop-down list.
[Copies]:
Specify the number of copies.
[Two-Sided]:
Select this check box to make 2-sided printouts.
[Pages]:
Specify the range of pages to print when printing a document with multiple pages.
The available settings differ depending on the application you are using.
