[To Portal]:
Displays the portal page of the Remote UI.
[AirPrint]:
Enables you to check the values entered in the AirPrint settings, such as the name and location of the machine. You can click [Edit...] to change the settings.
[Print Security Settings]:
Specify the settings required to print using SSL and authentication. (See "Configuring the Settings for Printing Using SSL and Authentication.")
[SSL Settings]:
Enables you to change the key and certificate used for SSL. (See "Configuring the Settings for Printing Using SSL and Authentication.")
[Key and Certificate Settings]:
Enables you to generate and install a key and certificate, or request a certificate to be issued. (See "Requesting Certificate Signing.")
