e-ManualTopSite mapHelp
Category Top
Printing Functions
[Basic Settings] Tab
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Printing Fundamentals
Printing
Viewing Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing from a Computer (Mac OS)
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Viewing Help
Scaling Documents
Setting Custom Paper Sizes
Using [Presets] for Printing
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Print Quality
Layout
Auto Error Skip
Secure Print Delete Time
Timeout
Finishing
Copy Set Numbering
Personality
Mode Priority
Color Mode
Gradation Settings
Compressed Image Output
Initialize
UFR II Settings
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
CMS (Matching) Selection
CMS (Matching)/Gamma
Gamma Correction
Paper Save
Advanced Smoothing
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code (Symbol Set)
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
Gamma Correction
Advanced Smoothing
PS Settings
Job Timeout
Print PS Errors
Pure Black Text
Black Overprint
RGB Source Profile
CMYK Simulation Profile
Use Grayscale Profile
Output Profile
Matching Method
RGB Pure Black Process
CMYK Pure Black Process
Halftones
Brightness
Composite Overprint
Advanced Smoothing
Grayscale Conversion
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
ICC Profile Settings
Photo Correct. (Color Only)
Halftones
Gray Compensation
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Pure Black Text
Black Overprint
RGB Source Profile
Output Profile
Matching Method
Halftones
Brightness
Composite Overprint
Advanced Smoothing
XPS Settings
Matching Mode
Gamma Correction
Photo Correct.(Color Only)
Halftones
Gray Compensation
Advanced Smoothing
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
AirPrint
What Is AirPrint?
Before Printing
Printing Using AirPrint
Canceling AirPrint Printing
Using the AirPrint Portal Page
Configuring the Settings for Printing Using SSL and Authentication
Requesting Certificate Signing
Troubleshooting for AirPrint
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Top » Print » Setting the Machine (PS/PCL/UFR II Printer) » Some Basic Facts about Fonts » Fonts and Scalable Fonts
0UKW-0RS
There are two types of fonts available, and these fonts are distinguished by the type of data from which they are formed.
Bitmapped fonts
Scalable fonts
Bitmapped Fonts
Each character of bitmapped fonts are composed of a grid of small dots and stored in the machine's memory in dot matrix format.
Bitmapped fonts are fixed in size and specified by characteristics called attributes, such as typeface, stroke weight, style and so on. Various types of bitmapped fonts are produced by the combination of these attributes.
Scalable Fonts
With scalable fonts, characters are freely enlarged or compressed from the one point to any size you wish in 0.1 point increments.
Standard Scalable Fonts (PCL)
With scalable fonts, characters are freely enlarged or compressed from one point to any size you wish in 0.1 point increments. (The maximum range of scaling depends on the size of the memory installed in the machine and the size of the paper used.)
The following scalable typefaces are included with the machine.
Albertus Extra Bold
Garamond Halbfett
New Century Schoolbook Bold Italic
Albertus Medium
Garamond Kursiv
New Century Schoolbook Italic
Antique Olive
Garamond Kursiv Halbfett
New Century Schoolbook Roman
Antique Olive Bold
Helvetica
Palatino Bold
Antique Olive Italic
Helvetica Bold
Palatino Bold Italic
Arial
Helvetica Bold Oblique
Palatino Italic
Arial Bold
Helvetica Narrow
Palatino Roman
Arial Bold Italic
Helvetica Narrow Bold
Symbol
Arial Italic
Helvetica Narrow Bold Oblique
SymbolPS
CG Omega
Helvetica Narrow Oblique
Times Bold
CG Omega Bold
Helvetica Oblique
Times Bold Italic
CG Omega Bold Italic
ITC Avant Garde Gothic Book
Times Italic
CG Omega Italic
ITC Avant Garde
Times New
CG Times
Gothic Book Oblique
Times New Bold
CG Times Bold
ITC Avant Garde Gothic Demi
Times New Bold Italic
CG Times Bold Italic
ITC Avant Garde
Times New Italic
CG Times Italic
Gothic Demi Oblique
Times Roman
Clarendon Condensed
ITC Bookman Demi
Univers Medium
Coronet
ITC Bookman Demi Italic
Univers Bold
Courier
ITC Bookman Light
Univers Bold Condensed
Courier Bold
ITC Bookman Light Italic
Univers Bold Condensed Italic
Courier Bold Italic
ITC Zapf Chancery Medium Italic
Univers Bold Italic
Courier Italic
ITC Zapf Dingbats
Univers Medium Italic
CourierPS
Letter Gothic
Univers Medium Condensed
CourierPS Bold
Letter Gothic Bold
Univers Medium Condensed Italic
CourierPS Oblique
Letter Gothic Italic
Wingdings
CourierPS Bold Oblique
Marigold
Garamond Antiqua
OCR Sets Fonts (PCL)
OCR A
OCR B
Symbol Sets (For Scalable Typefaces Only)
The following symbol sets are included with the machine.
ASCII (ISO6)
MC Text*
PS Text
DeskTop
Microsoft Publishing
Roman-8
ITC Zapf Dingbats MS
OCR-A
Roman-9*
ISO 8859-1 Latin1
OCR-B
Symbol
ISO 8859-10 Latin 6
PC-1004 (OS/2)
Unicode
ISO 8859-2 Latin 2
PC-775
Ventura International
ISO 8859-9 Latin 5
PC-8
Ventura Math
ISO French (ISO69)
PC-8 D/N
Ventura US
ISO German (ISO21)
PC-8 Greek
Windows 3.0 Latin 1*
ISO Italian (ISO15)
PC-850
Windows Baltic*
ISO Latin 9*
PC-852
Windows 3.1 Latin 1*
ISO Norwegian (ISO60)
PC-858*
Windows 3.1 Latin 2*
ISO Spanish (ISO17)
PC-860 Portugal
Windows 3.1 Latin 5*
ISO Swedish:names (ISO11)
PC-865 Norway
Wingdings
ISO United Kingdom (ISO4)
PC-Turkish
Arabic-8
Windows 3.1 Arabic
PC-864,Latin/Arabic
PC-Cyrillic
ISO-8859/5 Latin/Cyrillic
Windows Latin/Cyrillic
PC-851, Latin/Greek
ISO-8859/7 Latin/Greek
PC-8 Latin/Greek
Greek-8
Windows Latin/Greek
PC-862,Latin/Hebrew
ISO-8859/8 Latin/Hebrew
Hebrew-7
Hebrew-8
Legal
Pi Font
Math-8
PS Math*
*Supports the euro symbol.
PS Fonts
AlbertusMT
GillSansCE Italic
NewCenturySchlbk BoldItalic
AlbertusMT Italic
GillSans Bold
NewCenturySchlbkCE
AlbertusMT Light
GillSansCE Bold
BoldItalic
AntiqueOlive Roman
GillSans BoldItalic
NewYork
AntiqueOliveCE Roman
GillSansCE BoldItalic
NewYorkCE
AntiqueOlive Italic
GillSans Condensed
Optima
AntiqueOliveCE Italic
GillSansCE Condensed
OptimaCE Roman
AntiqueOlive Bold
GillSans BoldCondensed
Optima Italic
AntiqueOliveCE Bold
GillSansCE BoldCondensed
OptimaCE Italic
AntiqueOlive Compact
GillSans Light
Optima Bold
AntiqueOliveCE Compact
GillSansCE Light
OptimaCE Bold
Apple Chancery
GillSans LightItalic
Optima BoldItalic
Apple ChanceryCE
GillSansCE LightItalic
OptimaCE BoldItalic
ArialMT
GillSans ExtraBold
Oxford
ArialCE
GillSansCE ExtraBold
Palatino Roman
Arial ItalicMT
Goudy
PalatinoCE Roman
ArialCE Italic
Goudy Italic
Palatino Italic
Arial BoldMT
Goudy Bold
PalatinoCE Italic
ArialCE Bold
Goudy BoldItalic
Palatino Bold
Arial BoldItalicMT
Goudy ExtraBold
PalatinoCE Bold
ArialCE BoldItalic
Helvetica
Palatino BoldItalic
AvantGarde Book
HelveticaCE
PalatinoCE BoldItalic
AvantGardeCE Book
Helvetica Oblique
StempelGaramond Roman
AvantGarde BookOblique
HelveticaCE Oblique
StempelGaramondCE Roman
AvantGardeCE BookOblique
Helvetica Bold
StempelGaramond Italic
AvantGarde Demi
HelveticaCE Bold
StempelGaramondCE Italic
AvantGardeCE Demi
Helvetica BoldOblique
StempelGaramond Bold
AvantGarde DemiOblique
HelveticaCE BoldOblique
StempelGaramondCE Bold
AvantGardeCE DemiOblique
Helvetica Condensed
StempelGaramond BoldItalic
Bodoni
HelveticaCE Cond
StempelGaramondCE
BodoniCE
Helvetica Condensed Oblique
BoldItalic
Bodoni Italic
HelveticaCE CondObl
Symbol
BodoniCE Italic
Helvetica Condensed Bold
Taffy
Bodoni Bold
HelveticaCE CondBold
Times Roman
BodoniCE Bold
Helvetica Condensed BoldObl
TimesCE Roman
Bodoni BoldItalic
HelveticaCE CondBoldObl
Times Italic
BodoniCE BoldItalic
Helvetica Narrow
TimesCE Italic
Bodoni Poster
HelveticaCE Narrow
Times Bold
BodoniCE Poster
TimesCE Bold
Bodoni PosterCompressed
HelveticaCE NarrowBold
Times BoldItalic
BodoniCE PosterCompressed
Helvetica Narrow BoldOblique
TimesCE BoldItalic
Bookman Light
HelveticaCE NarrowBoldOblique
TimesNewRomanPSMT
BookmanCE Light
TimesNewRomanCE
Bookman LightItalic
HelveticaCE NarrowOblique
TimesNewRomanPS
BookmanCE LightItalic
HoeflerText Regular
ItalicMT
Bookman Demi
HoeflerTextCE Regular
TimesNewRomanCE Italic
BookmanCE Demi
HoeflerText Italic
TlmesNewRomanPS BoldMT
Bookman DemiItalic
HoeflerTextCE Italic
TimesNewRomanCE Bold
BookmanCE DemiItalic
HoeflerText Black
TimesNewRomanPS
Candid
HoeflerTextCE Black
BoldItalicMT
Chicago
HoeflerText BlackItalic
TimesNewRomanCE
Chicago CE
HoeflerTextCE BlackItalic
BoldItalic
Clarendon
HoeflerText Ornaments
Univers
ClarendonCE
JoannaMT
UniversCE Medium
Clarendon Light
JoannaMTCE
Univers Oblique
ClarendonCE Light
JoannaMT Italic
UniversCE Oblique
Clarendon Bold
JoannaMTCE Italic
Univers Bold
ClarendonCE Bold
JoannaMT Bold
UniversCE Bold
CooperBlack
JoannaMTCE Bold
Univers BoldOblique
CooperBlack Italic
JoannaMT BoldItalic
UniversCE BoldOblique
Copperplate ThirtyTwoBC
JoannaMTCE BoldItalic
Univers Light
Copperplate ThirtyThreeBC
LetterGothic
UniversCE Light
Coronet Regular
LetterGothicCE
Univers LightOblique
CoronetCE Regular
LetterGothic Slanted
Univers CE LightOblique
Courier
LetterGothicCE Slanted
Univers Condensed
CourierCE
LetterGothic Bold
UniversCE Condensed
Courier Oblique
LetterGothicCE Bold
Univers CondensedOblique
CourierCE Oblique
LetterGothic BoldSlanted
UniversCE
Courier Bold
LetterGothicCE BoldSlanted
CondensedOblique
CourierCE Bold
LubalinGraph Book
Univers CondensedBold
Courier BoldOblique
LubalinGraphCE Book
UniversCE CondensedBold
CourierCE BoldOblique
LubalinGraph BookOblique
Univers Condensed
Eurostile
LubalinGraphCE BookOblique
BoldOblique
EurostileCE
LubalinGraph Demi
UniversCE Condensed
Eurostile Bold
LubalinGraphCE Demi
BoldOblique
EurostileCE Bold
LubalinGraph DemiOblique
Univers Extended
Eurostile ExtendedTwo
LubalinGraphCE DemiOblique
UniversCE Extended
EurostileCE
Marigold
Univers ExtendedObl
ExtendedTwo
Monaco
UniversCE ExtendedObl
Eurostile BoldExtendedTwo
MonacoCE
Univers BoldExt
EurostileCE
MonaLisa Recut
UniversCE BoldExt
BoldExtendedTwo
NewCenturySchlbk Roman
Univers BoldExtObl
Geneva
NewCenturySchlbkCE Roman
UniversCE BoldExtObl
GenevaCE
NewCenturySchlbk Italic
Wingdings Regular
GillSans
NewCenturySchlbkCE Italic
ZapfChancery MediumItalic
GillSansCE Roman
ZapfChanceryCE MediumItalic
GillSans Italic
NewCenturySchlbkCE Bold
ZapfDingbats
