e-ManualTopSite mapHelp
Top » Maintenance » Replacement Parts » Replacing the Toner Cartridge
0UKW-069
When the Black toner or all of the toners run out completely and prints can no longer be made, a screen with instructions on how to replace the toner cartridge appears on the touch panel display. Follow the procedure described below to replace the toner cartridge.
If you press [Close], you can continue operations, such as setting modes, even if you do not replace the toner cartridge immediately.
WARNING
Do not burn or throw used toner cartridges into open flames, as this may cause the toner to ignite, resulting in burns or a fire.
If you accidentally spill or scatter toner, carefully wipe up the loose toner with a damp, soft cloth and avoid inhaling any toner dust. Do not use a vacuum cleaner that is not equipped with safety measures to prevent dust explosions to clean up loose toner. Doing so may cause damage to the vacuum cleaner or result in a dust explosion due to static discharge.
CAUTION
Keep toner out of the reach of small children.
If toner is ingested, consult a physician immediately.
If toner gets onto your hands or clothing, wash it off immediately with cold water. Washing it off with warm water will set the toner, and make it impossible to remove the toner stains.
Use only toner cartridges intended for use with this machine.
For information on the supported Canon genuine toner, see "Replacement Parts."
Do not replace toner cartridges until the message prompting you to do so appears.
Do not attempt to replace the toner cartridge while the machine is printing.
The color of the toner to be replaced is displayed on the touch panel display. If multiple toner cartridges must be replaced, replace the toner cartridges in the following order: Black, Yellow, Magenta, Cyan.
If you continue printing in black-and-white after cyan, magenta, or yellow toner runs out, do not remove the depleted toner cartridges from the machine.
You can set the machine to display a message indicating that the remaining toner is low. (See "Displaying the Remaining Toner Error Message," and "Deleting the Remaining Toner Error Message.")
Complete instructions on how to replace the toner cartridge can be accessed by pressing [Previous] or [Next] on the touch panel display.
If toner runs out during a print job, the remaining prints are made after you replace the toner cartridge.
If black toner is left, you can continue printing in black-and-white.
After replacing toner cartridges, if printed colors are different from the colors printed before you replaced the toner cartridges, perform [Adjust Gradation] in [Adjustment/Maintenance]. (See "Adjusting Gradation and Density.")
Press .
If the Black toner or all of the toners run out, this step is not necessary.
Remove the toner cartridge of the displayed color.
1. Open the front cover of the main unit.
2. Pull out the toner cartridge to replace.
Pull the toner cartridge out halfway, and then remove it completely while supporting it and keeping it straight with your other hand from underneath.
WARNING
Do not burn or throw used toner cartridges into open flames, as this may cause the toner remaining inside the cartridges to ignite, resulting in burns or a fire.
Do not subject the toner cartridge to shock or hit it. Doing so may cause the toner cartridge to leak.
Prepare the new toner cartridge.
1. Open the package of the toner cartridge, and remove the toner cartridge.
2. Hold the new toner cartridge in both hands as shown in the illustration, and shake it vertically approximately 10 times.
Do not shake the toner cartridge in the direction shown in the illustration. Doing so may cause the toner to not output properly.
4.
Insert the new toner cartridge.
1. Match the new toner cartridge with the slot on the main unit as shown in the illustration.
2. Push the new toner cartridge in as far as possible.
Support the new toner cartridge with your hand from underneath while pushing it into the machine with your other hand.
5.
Close the front cover of the main unit.
CAUTION
When closing the cover, be careful not to get your fingers caught, as this may result in personal injury.
After replacing the toner cartridge, the following screen may appear.
Make sure to check the displayed status of the toner cartridge which is attached to the location within the frame.
Message
Status
Wrong cartridge color may be inserted.
A toner cartridge of the wrong color is inserted.
Wrong item no. cart. may be inserted.
A toner cartridge with the wrong model number is inserted.
Toner cart. may be malfunctioning.
The inserted toner cartridge may have been damaged.
The correct toner cartridge is inserted.
To continue using the toner cartridge, press [I Agree]. If you select this option, the operation of the machine is not guaranteed.
To replace the toner cartridge, press [Cancel].
If you are not sure about the remedies, contact your local authorized Canon dealer from which you purchased the toner cartridge.
