0UKW-0HH
[Output]*, [Display Error]
This setting enables you to specify how the data should be treated if the data size of the print job is too large to be stored in the machine's memory.
The data is highly compressed (so it is able to be stored in memory), and then the job is printed. However, the print quality may diminish.
The job is canceled when the data size is too large.
Even if [Output] is selected and the data is highly compressed, the data may still be too large to be stored in the machine's memory. In this case, the job is canceled and an error is logged in the Print Log.
