e-ManualTopSite mapHelp
Category Top
Printing Functions
[Basic Settings] Tab
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Printing Fundamentals
Printing
Viewing Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing from a Computer (Mac OS)
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Viewing Help
Scaling Documents
Setting Custom Paper Sizes
Using [Presets] for Printing
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Print Quality
Layout
Auto Error Skip
Secure Print Delete Time
Timeout
Finishing
Copy Set Numbering
Personality
Mode Priority
Color Mode
Gradation Settings
Compressed Image Output
Initialize
UFR II Settings
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
CMS (Matching) Selection
CMS (Matching)/Gamma
Gamma Correction
Paper Save
Advanced Smoothing
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code (Symbol Set)
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
Gamma Correction
Advanced Smoothing
PS Settings
Job Timeout
Print PS Errors
Pure Black Text
Black Overprint
RGB Source Profile
CMYK Simulation Profile
Use Grayscale Profile
Output Profile
Matching Method
RGB Pure Black Process
CMYK Pure Black Process
Halftones
Brightness
Composite Overprint
Advanced Smoothing
Grayscale Conversion
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
ICC Profile Settings
Photo Correct. (Color Only)
Halftones
Gray Compensation
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Pure Black Text
Black Overprint
RGB Source Profile
Output Profile
Matching Method
Halftones
Brightness
Composite Overprint
Advanced Smoothing
XPS Settings
Matching Mode
Gamma Correction
Photo Correct.(Color Only)
Halftones
Gray Compensation
Advanced Smoothing
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
AirPrint
What Is AirPrint?
Before Printing
Printing Using AirPrint
Canceling AirPrint Printing
Using the AirPrint Portal Page
Configuring the Settings for Printing Using SSL and Authentication
Requesting Certificate Signing
Troubleshooting for AirPrint
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Top » Print » Bar Code Printing » Troubleshooting » Printing Problems
Printing Problems
0UKW-0U0
If you have trouble printing bar codes, we recommend the following remedies.
The message "MEMORY OVERFLOW" appears.
Cause
The Bar Code Printing function is not enabled, resulting in the creation of oversized fonts that use up the memory.
Remedy
Set the BarDIMM menu to 'Enable', and print the data again.
Bar code data is printed as text.
Cause
The BarDIMM menu is set to 'Disable'.
Remedy
Bar codes are not readable.
Cause 1
The bar code data was not created properly.
Remedy
Make sure to use the correct format for the type of bar code that you want to make.
Cause 2
The bar code reader is not set to read the symbologies you are printing.
Remedy
Make sure that the bar code reader is compatible with the symbologies you are trying to print.
Bar code printing does not stop.
Cause
The character symbol set command has not been sent.
Remedy
Make sure to send the character symbol command, as well as any other font selection sequence after the bar code data (e.g., <Esc>(10U for PC-850).
The layout for the German 25 Postal bar code is not correct.
Cause
The size and text of the bar code are not printed as expected.
Remedy
To print the German 25 Postal bar code in the correct layout, use 124 for the p parameter and 300 for the h parameter. For example, <Esc>(s124p300h24642T.
An error message is displayed with the 2 of 5 Interleaved bar code.
Cause
The number of encoded digits is not even, in multiples of two.
Remedy
If you are using a checksum, you must send an odd number of digits. (The calculated checksum will add one character, making the total data length an even number.)
Narrow bar codes are not readable.
Cause
In all laser printers, thin lines do not have a perfectly clean edge because the toner particle shape is not square. This results in narrow black bars that are wider than the blank spaces of the same width.
Remedy
Fine tune the bar width using the b and s parameters to reduce the horizontal width of the thin black bars, or use the s parameter to widen the thin white bars (blank spaces).
Bar codes on the very top of the page are not printed correctly.
Cause
As bar codes are printed at the current cursor position from the baseline to the top of the page, they may not be printed correctly (i.e., wrong height or caption text in the middle of the bar code).
Remedy
Make sure that you set the cursor in a vertical position, compatible with the bar code height.
The 39 bar code is much longer than it should be.
Cause
The bar code selection sequence was sent before you sent the space characters to position the bar code. As a result, the spaces are separate from the bar code data, and the bar code is much wider than expected (usually across the page).
Remedy
When you position the cursor horizontally using blank spaces to position the bar code in the right place, you must send the bar code selection sequence after sending the space characters to move it horizontally.
If you can only send the bar code selection sequence at the beginning of the line, use the special 39 symbology specifications with no starting spaces (IDs 24670 and 24671). This symbology does not include the starting spaces in the bar code data.
A bar code calling sequence is inserted in a PCL5 macro.
Cause
A bar code calling sequence has been inserted into a PCL5 macro without the proper bar code data.
Remedy
Insert the bar code calling sequence with the bar code data into the PCL macro. If an application needs to send the same bar code multiple times, it can include the calling sequence with the PCL macro, and invoke it in the required number of occurrences.
