Top » Copy » Booklet Mode
Booklet Mode
0R9W-0LJ
This mode enables you to output copies as booklets.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
Saddle Stitch Booklet
This mode enables you to copy one-sided or two-sided originals so that the copies are made in a booklet layout.
When the Booklet Finisher-U1 is attached
Divided Booklet
This mode enables you to make a large document with many pages into a divided booklet.
Creep (Displacement) Correction
This mode enables you to adjust the position of the images in a booklet by calculating the width of the displacement between the outermost page and center page of the booklet.
*1 Trimmed
*2 After the pages are trimmed, the outer margins of all pages are equal.
*3 The inner margins are set so that the inner margins of the outermost pages are wider than the inner margins of the center pages. The placement of the images on each page is adjusted by calculating the amount of displacement between the outermost page and innermost page of the booklet.
The Saddle Stitch and Divided Booklet modes can be set only if the Booklet Finisher-U1 is attached.
Be sure to correctly set the paper type. When printing on special types of paper, such as heavy paper or transparencies, be sure to correctly set the paper type, especially if you are using heavy paper. If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty and require a service repair, or the paper could jam.
Make sure to place originals with a vertical (portrait) orientation vertically. If these originals are placed horizontally, the even numbered pages will be printed upside down.
The accuracy of folds created in the Saddle Stitch mode may vary, depending on the type and quantity of paper.
Press [Copy].
Press [Options] → [Booklet].
Specify the detailed Booklet settings→ press [Next].
If you place a two-sided original, press [2-Sided Original] → select the type of two-sided original → press [OK].
Performing Booklet Scanning:
Selecting the Original Size and Booklet Layout Size:
Press [Booklet Scan]
To fold each page of the original to use as two pages of the booklet, press [Do Not Booklet Scan].
If you do not use the Booklet Scan mode, you cannot select the layout of two-sided originals.
If the Booklet Scan mode is not used, you cannot select [Auto] of the original.
Press [Change] for <Original Size>.
Select the size of the original you have placed → press [OK].
You can select [Auto] to select the paper size automatically.
Press [Change] for <Bklt Layout Size>.
Select the paper size for finishing → press [OK].
Only 12" × 18", 11" × 17", LGL, or LTRR paper can be used.
4.
Specify the folding method, method for adding the cover, and the type of opening.
Folding and Saddle Stitching:
Adding Covers:
Select the type of opening:
Press [Fold + Saddle Stitch].
If you do not want to saddle stitch, select [Fold Only].
If you do not want to set the Fold and Saddle Stitch modes, select [Do Not Fold].
The maximum number of sheets that can be saddle stitched at one time is 16. If you want to saddle stitch 17 or more sheets, set the Divided Booklet mode.
If the number of sheets is 17 or more, the booklet is not saddle stitched.
If you select [Fold Only], only one sheet can be folded at one time.
Adding Covers:
Press [Add Cover] → [Print].
Press [Leave Blank] if you do not want to copy on the cover.
If you selected [Booklet Scan], you can set <Front Cover>, <Front Inside Cover>, <Back Inside Cover>, and <Back Cover> individually.
To set the paper for the cover, press [Change] → select the paper source → press [OK].
You must select the same paper size for the cover page as that used for the main document.
Only 14 lb bond to 28 lb bond (52 to 105 g/m2) paper can be used for the main document.
Only 14 lb bond to 80 lb cover (52 to 220 g/m2) paper can be used for the cover.
Press [Opening Type] → select the type of finishing → press [OK].
[Left Opening]: A booklet that opens to the left is created.
[Right Opening]: A booklet that opens to the right is created.
You can select the type of finishing only if [Booklet Scan] is set.
5.
To specify Divided Booklet, Creep Correction, or adjust the saddle stitch position, press [Set Details].
If you do not want to specify the detailed settings, proceed to step 6.
Making a divided booklet:
Setting the creep correction:
Adjusting the saddle stitch position:
Press [Divided Booklet] → set the number of sheets to divide → press [OK].
The number of saddle stitched booklets that the booklet tray can hold depends on the number of sheets that each booklet contains.
Press [Creep Correction] → select the correction method → press [OK].
If you select [Manual], press or to adjust the correction width.
Press [Change Fold/Stitch Pos.] → select the paper size for finishing.
Adjust the saddle stitch position using  or  → press [OK].
You can set [Change Fold/Stitch Pos.] only if you select [Fold + Saddle Stitch] or [Fold Only].
6.
Press [OK] → [OK] → [Close].
7.
Set the Booklet Tray guide to match the paper size.
12" x 18"/11" x 17"/LGL
LTRR
Make sure to set the Booklet Tray guide to match the paper size. Setting the Booklet Tray guide incorrectly may result in a paper jam.
Saddle stitching is not performed if there is only one output sheet.
The accuracy of folds may vary, depending on the type and quantity of paper.
