Making ID Card Copies (Copy ID Card)
0R9W-0RR
This mode enables you to copy both the front and back of an ID card onto a single sheet of paper.
This mode is useful when copying ID cards (identification cards) such as driver's licenses, because the orientation and print position of the images of both sides of the ID card are aligned automatically according to the paper size that you specify.
Place the ID card on the platen glass. The Copy ID Card mode cannot be used when the ID card is placed in the feeder.
Only LTR and LTRR paper can be specified for paper size.
Press [Copy].
Press [Options] → [Copy ID Card].
Press [Change] → select the paper to copy to → press [OK].
4.
Press [OK]→ [Close].
5.
Place the ID card on the platen glass face down.
If another originals are set in the feeder, you cannot start copying. Remove the originals from the feeder.
The scan size of the original is set as STMT. Make sure to place the original horizontally.
*1:
ID card
*2:
scan size
*3:
the platen glass
6.
Press
(numeric keys) to enter the desired copy quantity (1 to 999).
If you make a mistake when entering values, press
(Clear)→ enter the correct value.
7.
Press
(Start).
Scanning of the front side starts.
Once scanning is completed, the following screen is displayed.
8.
Turn the ID card over so that its back side is face down→ press
(Start).
Scanning of the back side starts.
9.
After the back side of the ID card is scanned, printing is performed automatically.
