Top » Copy » Changing Copy Ratios
0R9W-0L7
You can manually specify basic copy ratios, or set them automatically.
You can set a copy (zoom) ratio from 25% to 400%.
Place your original horizontally when enlarging in the following ways with a preset zoom: Placing an original horizontally means setting the original with the longer side sideways. (See "Orientation.")
LTR → 11" x 17"
STMT → 11" x 17"
Press [Copy].
Press [Copy Ratio] → set the copy ratio as necessary.
Preset Zoom:
Zoom by Percentage:
Auto Zoom:
Fit to Page:
Preset Zoom:
You can use preset copy (zoom) ratios to enlarge or reduce standard size originals to other standard sizes.
Select the copy ratio.
Zoom by Percentage:
You can enlarge or reduce originals by any copy ratio in 1% increments. The same copy ratio is used for the horizontal and vertical axes.
Press [-] or [+] to specify the copy ratio.
Auto Zoom:
You can automatically enlarge or reduce an original to a specified paper size. The same copy ratio is used for the horizontal and vertical axes.
Press [Auto]
If you set [Auto], you have to select a paper size manually. If you do not select a paper size, the copy ratio is automatically set to match the size of paper loaded in paper drawer 1.
Fit to Page:
This mode slightly reduces the original when copying to paper of the same size. This enables you to avoid unwanted cropping at the edges of large images and text.
Press [Fit to Page].
Press [OK].
If you are reducing 11" x 17" originals to LTR size with [Auto Recognize Original Orientation] set to 'Off', load LTRR paper in a paper drawer or the multi-purpose tray.
You cannot copy highly transparent originals, such as transparencies, in the Auto Zoom mode. Use the Preset Zoom or Zoom by Percentage mode instead.
To use [Auto], your originals must conform to one of the following standard paper sizes:
11"×17", LGL, LTR, LTRR, EXEC, STMT, STMTR (If you copy an STMTR original with [Auto] selected, a screen for selecting the original size is displayed. Select the appropriate original size.)
If the output size differs from your specified copy ratio, you can adjust it using [Fine Adjust Zoom] in [Adjustment/Maintenance] (Settings/Registration). (See "Fine Adjust Zoom.")
The reduction ratios when [Fit to Page] is specified are:
11" x 17"/LGL: approximately 98%
LTR: approximately 97%
STMT: approximately 96%
To return the ratio to 100%, press [Direct (100%)].
