Top » Copy » Appendix
Appendix
0R9W-0RU
Relationship Between the Original Orientation and Paper Orientation
Use this appendix when stapling output printed on paper that is preprinted with a logo, etc.
If you are copying onto the back side of a previously printed sheet, load the paper as indicated below.
Paper drawer: Load the side to copy on face up.
Multi-purpose tray: Load the side to copy on face down.
The stapling position for the Eco (Staple-Free) mode is the same as that for the Corner staple mode.
When Stapling on the Right
Other Settings
Example of Stapling Position
Corner: Top Right
Double: Right
LTR, EXEC
Corner: Top Right
Double: Top
11" x 17", LGL, LTRR
Corner: Top Right
LTR, EXEC
Corner: Top Right
Double: Right
Preprinted paper
Loading location: Paper drawer
Preprinted paper: Face up
Loading location: Multi-purpose tray
Preprinted paper: Face down
Original
Loading location: Platen glass
Original: Face down
Stapling setting
Corner: Top Right
Double: Right
Corner: Bottom Right
Double: Right
Corner: Top Right
Corner: Top Right
Double: Right
Loading location: Feeder
Original: Face up
Stapling setting
Corner: Top Right
Double: Right
Double: Right
Corner: Top Right
Corner: Top Right
Double: Right
Auto Rotation Setting
Both ON and OFF available
Both ON and OFF available (ON when
loaded vertically in the multi-purpose
tray or vertically in a paper drawer)
When Stapling on the Left
Other Settings
Corner: Top Left
Double: Left
LTR, EXEC
Corner: Top Left
Double: Top
Corner: Top Left
LTR, EXEC
Corner: Top Left
Double: Left
Preprinted paper
Original
Original: Face down
Stapling setting
Corner: Top Left
Double: Left
Corner: Top Right
Double: Right
Corner: Top Left
Corner: Top Left
Double: Left
Original: Face up
Stapling setting
Corner: Top Left
Double: Left
Corner: Top Right
Double: Right
Corner: Top Left
Corner: Top Left
Double: Left
(ON when
When Not Stapling
Other Settings
Example Output
LTR, EXEC
11" x 17", LGL
LTR, LTRR, EXEC
11" x 17", LGL
Preprinted paper
Original
Original: Face down
Original: Face up
(ON when
Unavailable Combination of Functions
The following tables show the unavailable combinations of settings when you want to set more than one function at a time.
Function
Functions that Cannot Be Used in Combination
Preset Zoom
Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, Auto Zoom*1, Set by Length*1, Poster (Number of Output Pages)*1, Poster (%)*1, N on 1*1, Booklet Scanning*1, Divided Booklet*1, Creep Correction*1, Copy ID Card
Zoom by Percentage
Preset Zoom*1, XY Independent*1, Auto XY Ratio*1, Auto Zoom*1, Set by Length*1, Poster (Number of Output Pages)*1, Poster (%)*1, N on 1*1, Booklet Scanning*1, Divided Booklet*1, Creep Correction*1, Copy ID Card
XY Independent
Preset Zoom*1, Zoom by Percentage*1, Auto XY Ratio*1, Auto Zoom*1, Set by Length*1, Poster (Number of Output Pages)*1, Poster (%)*1, N on 1*1, Booklet Scanning*1, Divided Booklet*1, Creep Correction*1, Copy ID Card
Auto XY Ratio
Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Auto Zoom*1, Set by Length*1, Automatic Paper Selection, Free Size, Poster (Number of Output Pages)*1, Poster (%)*1, N on 1*1, Repeat Images (Auto), Repeat Images (Auto) + Framing, Booklet Scanning*1, Between Batches, Divided Booklet*1, Creep Correction*1, Copy ID Card
Auto Zoom
Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, Set by Length*1, Automatic Paper Selection, Free Size, Poster (Number of Output Pages)*1, Poster (%)*1, Repeat Images (Auto), Repeat Images (Auto) + Framing, Between Batches, Copy ID Card
Set by Length
Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, Auto Zoom*1, Poster (Number of Output Pages)*1, Poster (%)*1, Copy ID Card
Fit to Page
Free Size, Poster (Number of Output Pages), Poster (%), N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Booklet Scanning, Do Not Booklet Scan, Between Batches, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Copy ID Card
*1 If you select these modes in combination, the mode which is set last has priority.
Function
Manual Paper Selection*1, Custom Size*1, Free Size*1, Poster (Number of Output Pages)*1, N on 1*1, Booklet Scanning*1, Do Not Booklet Scan*1, Between Batches, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Saddle Stitch*1, Saddle Fold*1, Divided Booklet*1, Creep Correction*1, Copy ID Card
Automatic Paper Selection*1, Custom Size*1, Free Size*1, Between Batches, Print on Tab*1
Custom Size
Automatic Paper Selection*1, Manual Paper Selection*1, Free Size*1, 1-Sided2-Sided, Book2-Sided, 2-Sided2-Sided, Poster (Number of Output Pages), Poster (%), Book2 Pages, N on 1, Booklet Scanning, Do Not Booklet Scan, Between Batches, Eco (Staple-Free), Divided Booklet, Creep Correction, Copy ID Card
Free Size
XY Independent, Auto Zoom, Fit to Page, Automatic Paper Selection*1, Manual Paper Selection*1, Custom Size*1, 1-Sided2-Sided, Book2-Sided, 2-Sided2-sided, Poster (Number of Output Pages), Poster (%), Book2 Pages, N on1, Shift (By Position), Shift (By Numeric Keys), Repeat Images, Repeat Images (Auto), Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Staple, Eco (Staple-Free), Saddle Stitch, Saddle Fold, page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Secure Watermark, Scan Lock Information, Tracking Information, Copy ID Card
Scanning Originals Loaded in the Feeder
Book2-Sided, Poster (Number of Output Pages), Poster (%), Book2 Pages
Function
Collate
Poster (Number of Output Pages)*1, Poster (%)*1, Transparency Cover Sheets*1, Booklet Scanning*1, Do Not Booklet Scan, Between Batches, Group*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Offset Group*1, Staple*1, Eco (Staple-Free)*1, Saddle Stitch*1, Divided Booklet*1, Creep Correction*1, Copy ID Card
Group
Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Offset Group*1, Staple*1, Eco (Staple-Free)*1, Saddle Stitch*1, Saddle Fold, Copy Sample, Copy Set Numbering, Divided Booklet, Creep Correction, Secure Watermark*2, Copy ID Card
Automatic Paper Selection, Free Size, Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Group*1, Offset Collate, Offset Group, Staple, Eco (Staple-Free), Saddle Stitch, Saddle Fold, Divided Booklet, Creep Correction, Copy ID Card
Automatic Paper Selection, Free Size, Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Collating*1, Offset Collate, Offset Group, Staple, Eco (Staple-Free), Saddle Stitch, Saddle Fold, Copy Sample, Copy Set Numbering, Divided Booklet, Creep Correction, Secure Watermark*2, Copy ID Card
Offset Collate
Poster (Number of Output Pages)*1, Poster (%)*1, Transparency Cover Sheets*1, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group*1, Offset Group, Staple*1, Eco (Staple-Free)*1, Saddle Stitch*1, Saddle Fold, Creep Correction*1, Copy ID Card*1
Offset Group
Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate*1, Staple*1, Eco (Staple-Free)*1, Saddle Stitch*1, Saddle Fold, Copy Sample, Copy Set Numbering, Divided Booklet, Creep Correction, Secure Watermark*2, Copy ID Card
Staple
Free Size, Poster (Number of Output Pages), Poster (%), Mirror Image, Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Eco (Staple-Free)*1, Saddle Stitch*1, Saddle Fold, Divided Booklet, Creep Correction, Copy ID Card
Eco (Staple-Free)
Custom Size, Free Size, Poster (Number of Output Pages), Poster (%), Mirror Image, Transparency Cover Sheets, Booklet Scanning, Do not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple*1, Saddle Stitch, Saddle Fold, Divided Booklet, Creep Correction, Copy ID Card
Saddle Stitch
Automatic Paper Selection, Free Size, Book2-Sided, 2-Sided1-Sided, Poster (Number of Output Pages), Poster (%), Book2 Pages, N on 1, Mirror Image, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple*1, Eco (Staple-Free), Saddle Fold, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Copy ID Card
Saddle Fold
Automatic Paper Selection, Free Size, Book2-Sided, 2-Sided1-Sided, Poster (Number of Output Pages), Poster (%), Book2 Pages, N on 1, Mirror Image, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Eco (Staple-Free), Saddle Stitch, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Copy ID Card
*2 You cannot combine these modes with Copy Set Numbering for Secure Watermark.
Function
1-Sided2-Sided
Custom Size, Free Size, Book2-Sided*1, 2-Sided2-Sided*1, 2-Sided1-Sided*1, Poster (Number of Output Pages), Poster (%), Book2 Pages, Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Divided Booklet, Creep Correction, Copy ID Card
Book2-Sided
Custom Size, Free Size, 1-Sided2-Sided*1, 2-Sided2-Sided*1, 2-Sided1-Sided*1, Poster (Number of Output Pages), Poster (%), Book2 Pages, N on 1, Erase Binding, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Scanning Originals Loaded in the Feeder, Between Batches, Saddle Stitch, Saddle Fold, Different Size Originals, Divided Booklet, Creep Correction, Print & Check, Copy ID Card
2-Sided2-Sided
Custom Size, Free Size, 1-Sided2-Sided*1, Book2-Sided*1, 2-Sided1-Sided*1, Poster (Number of Output Pages), Poster (%), Book2 Pages, Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Divided Booklet, Creep Correction, Copy ID Card
2-Sided1-Sided
1-Sided2-Sided*1, Book2-Sided*1, 2-Sided2-Sided*1, Poster (Number of Output Pages), Poster (%), Book2 Pages, Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Saddle Stitch, Saddle Fold, Divided Booklet, Creep Correction, Copy ID Card
Auto (Color/Black), Background Density (Auto), Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, Auto Zoom*1, Set by Length*1, Fit to Page, Automatic Paper Selection, Custom Size, Free Size, 1-Sided2-Sided, Book2-Sided, 2-Sided2-Sided, 2-Sided1-Sided, Poster (%)*1, Book2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images, Repeat Images (Auto), Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Scanning Originals Loaded in the Feeder, Job Build, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Eco (Staple-Free), Saddle Stitch, Saddle Fold, Different Size Originals, Copy Sample, Divided Booklet, Creep Correction, Print & Check, Copy ID Card
Poster (%)
Auto (Color/Black), Background Density (Auto), Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, Auto Zoom*1, Set by Length*1, Fit to Page, Custom Size, Free Size, 1-Sided2-Sided, Book2-Sided, 2-Sided2-Sided, 2-Sided1-Sided, Poster (Number of Output Pages)*1, Book2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images, Repeat Images (Auto), Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Scanning Originals Loaded in the Feeder, Job Build, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Eco (Staple-Free), Saddle Stitch, Saddle Fold, Different Size Originals, Copy Sample, Divided Booklet, Creep Correction, Print & Check, Copy ID Card
Book2 Pages
Custom Size, Free Size, 1-Sided2-Sided, Book2-Sided, 2-Sided2-Sided, 2-Sided1-Sided, Poster (Number of Output Pages), Poster (%), N on 1, Erase Binding, Repeat Images, Repeat Images (Auto), Framing,Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Scanning Originals Loaded in the Feeder, Between Batches, Saddle Stitch, Saddle Fold, Different Size Originals, Divided Booklet, Creep Correction, Print & Check, Copy ID Card
N on 1
Fit to Page, Automatic Paper Selection, Custom Size, Free Size, Book2-Sided, Poster (Number of Output Pages), Poster (%), Book2 Pages, Erase Original Frame, Erase Book Frame, Shift (By Numeric Keys), Mirror Image, Repeat Images, Repeat Images (Auto), Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Saddle Stitch, Saddle Fold, Different Size Originals, Divided Booklet, Creep Correction, Print & Check, Copy ID Card
Fit to Page, Poster (Number of Output Pages), Poster (%), N on 1, Erase Book Frame*1, Erase Binding*1, Mirror Image, Repeat Images, Repeat Images (Auto), Framing, Booklet Scanning, Do Not Booklet Scan, Between Batches, Divided Booklet, Creep Correction, Copy ID Card
Erase Book Frame
Fit to Page, Poster (Number of Output Pages), Poster (%), N on 1, Erase Original Frame*1, Erase Binding*1, Mirror Image, Repeat Images, Repeat Images (Auto), Framing, Booklet Scanning, Do Not Booklet Scan, Between Batches, Divided Booklet, Creep Correction, Copy ID Card
Erase Binding
Fit to Page, Book2-Sided, Poster (Number of Output Pages), Poster (%), Book2 Pages, Erase Original Frame*1, Erase Book Frame*1, Mirror Image, Repeat Images, Repeat Images (Auto), Framing, Booklet Scanning, Do Not Booklet Scan, Between Batches, Divided Booklet, Creep Correction, Copy ID Card
Interrupt
Between Batches
Function
Shift (By Position)
Free Size, Poster (Number of Output Pages), Poster (%), Shift (By Numeric Keys)*1, Mirror Image, Repeat Images, Repeat Images (Auto), Between Batches, Copy ID Card
Free Size, Poster (Number of Output Pages), Poster (%), N on 1, Shift (By Position)*1, Mirror Image, Repeat Images, Repeat Images (Auto), Booklet Scanning, Do Not Booklet Scan, Between Batches, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Copy ID Card
Gutter
Poster (Number of Output Pages), Poster (%), Mirror Image, Repeat Images, Repeat Images (Auto), Booklet Scanning, Do Not Booklet Scan, Between Batches, Divided Booklet, Creep Correction, Scan Lock Information, Copy ID Card
Free Size, 1-Sided2-Sided, Book2-Sided, 2-Sided2-Sided, 2-Sided1-Sided, Poster (Number of Output Pages), Poster (%), Book2 Pages, N on 1, Mirror Image, Repeat Images, Repeat Images (Auto), Framing, Blanking, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Eco (Staple-Free), Saddle Stitch, Saddle Fold, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Print & Check, Copy ID Card
Front Cover
Free Size, Book2-Sided, Poster (Number of Output Pages), Poster (%), Book2 Pages, N on 1, Mirror Image, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Between Batches, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Saddle Fold, Page Numbering*3, Copy Set Numbering*3, Watermark*3, Print Date*3, Divided Booklet, Creep Correction, Copy ID Card
*3 You can set these modes in combination, but cannot print on Front Cover, Back Cover, or Sheets.
Function
Booklet Scanning
Fit to Page, Custom Size, Free Size, 1-Sided2-Sided, Book2-Sided, 2-Sided2-Sided, 2-Sided1-Sided, Poster (Number of Output Pages), Poster (%), Book2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images, Repeat Images (Auto), Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Do Not Booklet Scan, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Group, Staple, Eco (Staple-Free), Saddle Stitch, Saddle Fold, Hole Punch, Different Size Originals, Watermark, Print Date, Divided Booklet*1, Print & Check, Secure Watermark, Scan Lock Information, Tracking Information, Copy ID Card
Do Not Booklet Scan
Fit to Page, Automatic Paper Selection, Custom Size, Free Size, 1-Sided2-Sided, Book2-Sided, 2-Sided2-Sided, 2-Sided1-Sided, Poster (Number of Output Pages), Poster (%), Book2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images, Repeat Images (Auto), Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Eco (Staple-Free), Saddle Stitch, Saddle Fold, Different Size Originals, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Print & Check, Secure Watermark, Scan Lock Information, Tracking Information, Copy ID Card
Divided Booklet
Fit to Page, Automatic Paper Selection, Custom Size, Free Size, 1-Sided2-Sided, Book2-Sided, 2-Sided2-Sided, 2-Sided1-Sided, Poster (Number of Output Pages), Poster (%), Book2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images, Repeat Images (Auto), Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning*1, Do Not Booklet Scan, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Eco (Staple-Free), Saddle Stitch, Saddle Fold, Different Size Originals, Watermark, Print Date, Print & Check, Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information, Copy ID Card
Creep Correction
Fit to Page, Automatic Paper Selection, Custom Size, Free Size, 1-Sided2-Sided, Book2-Sided, 2-Sided2-Sided, 2-Sided1-Sided, Poster (Number of Output Pages), Poster (%), Book2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images, Repeat Images (Auto), Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Do Not Booklet Scan, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Eco (Staple-Free), Saddle Stitch, Saddle Fold, Different Size Originals, Watermark, Print Date, Print & Check, Secure Watermark, Scan Lock Information, Tracking Information, Copy ID Card
Function
Sharpness
Between Batches, Secure Watermark, Scan Lock Information, Tracking Information
Nega/Posi
Between Batches, Secure Watermark, Scan Lock Information, Tracking Information, Copy ID Card
Mirror Image
Fit to Page, Poster (Number of Output Pages), Poster (%), N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Staple, Eco (Staple-Free), Saddle Stitch, Saddle Fold, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Secure Watermark, Scan Lock Information, Tracking Information, Copy ID Card
Repeat Images
Fit to Page, Free Size, Book2-Sided, Poster (Number of Output Pages), Poster (%), Book2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images (Auto)*1, Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Different Size Originals, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Print & Check, Secure Watermark, Scan Lock Information, Copy ID Card
Auto XY Ratio, Auto Zoom, Fit to Page, Automatic Paper Selection, Free Size, Book2-Sided, Poster (Number of Output Pages), Poster (%), Book2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images*1, Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Different Size Originals, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Print & Check, Secure Watermark, Scan Lock Information, Tracking Information, Copy ID Card
Framing
Free Size, Book2-Sided, Poster (Number of Output Pages), Poster (%), Book2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Between Batches, Divided Booklet, Creep Correction, Merge Job Blocks, Secure Watermark, Scan Lock Information, Tracking Information, Copy ID Card
Blanking
Free Size, Book2-Sided, Poster (Number of Output Pages), Poster (%), Book2 Pages, N on 1, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Between Batches, Divided Booklet, Creep Correction, Secure Watermark, Scan Lock Information, Tracking Information, Copy ID Card
Job Build
Poster (Number of Output Pages), Poster (%), Between Batches, Copy ID Card
Between Batches
Background Density (Adjust All Color), Auto XY Ratio, Auto Zoom, Fit to Page, Automatic Paper Selection, Manual Paper Selection, Custom Size, Free Size, Book2-Sided, Sharpness, Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Poster (Number of Output Pages), Poster (%), Book2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Nega/Posi, Mirror Image, Repeat Images, Repeat Images (Auto), Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Job Build, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Eco (Staple-Free), Saddle Stitch, Saddle Fold, Different Size Originals, Copy Sample, Interrupt, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Print & Check, Secure Watermark, Scan Lock Information, Tracking Information, Copy ID Card
Book2-Sided, Poster (Number of Output Pages), Poster (%), Book2 Pages, N on 1, Repeat Images, Repeat Images (Auto), Booklet Scanning, Do Not Booklet Scan, Between Batches, Divided Booklet, Creep Correction, Copy ID Card
Copy Sample
Poster (Number of Output Pages), Poster (%), Between Batches, Group*1, Rotate 90 Degrees: Group*1, Offset Group*1, Copy ID Card
Function
Page Numbering
Fit to Page, Free Size, Adjust One-Touch Color (Sepia Tone), Shift (By Numeric Keys), Mirror Image, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Front Cover*3, Sheets/Chapter Pages*3, Do Not Booklet Scan, Between Batches, Saddle Stitch, Saddle Fold, Copy Set Numbering*5, Watermark*5, Print Date*5, Two Colors, Copy ID Card
Copy Set Numbering
Fit to Page, Free Size, Adjust One-Touch Color (Sepia Tone), Shift (By Numeric Keys), Mirror Image, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Front Cover*3, Sheets/Chapter Pages*3, Do Not Booklet Scan, Between Batches, Group, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Saddle Fold, Page Numbering*5, Watermark*5, Print Date*5, Two Colors, Secure Watermark, Scan Lock Information, Tracking Information, Copy ID Card
Watermark
Fit to Page, Free Size, Adjust One-Touch Color (Sepia Tone), Shift (By Numeric Keys), Mirror Image, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Front Cover*3, Sheets/Chapter Pages*3, Booklet Scanning, Do Not Booklet Scan, Between Batches, Saddle Stitch, Saddle Fold, Page Numbering*5, Copy Set Numbering*5, Print Date*5, Two Colors, Divided Booklet, Creep Correction, Secure Watermark, Scan Lock Information, Tracking Information, Copy ID Card
Print Date
Fit to Page, Free Size, Adjust One-Touch Color (Sepia Tone), Shift (By Numeric Keys), Mirror Image, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Front Cover*3, Sheets/Chapter Pages*3, Booklet Scanning, Do Not Booklet Scan, Between Batches, Saddle Stitch, Saddle Fold, Page Numbering*5, Copy Set Numbering*5, Watermark*5, Two Colors, Divided Booklet, Creep Correction, Secure Watermark, Scan Lock Information, Tracking Information, Copy ID Card
Print & Check
Book2-Sided, 2-Sided2-Sided, 2-Sided1-Sided, Poster (Number of Output Pages), Poster (%), Book2 Pages, N on 1, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Between Batches, Divided Booklet, Creep Correction, Copy ID Card
Secure Watermark
Free Size, Sharpness, Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Single Color, Nega/Posi, Mirror Image, Repeat Images, Repeat Images (Auto), Framing, Blanking, Booklet Scanning, Do Not Booklet Scan, Between Batches, Group*2, Rotate 90 Degrees: Group*2, Offset Group*2, Copy Set Numbering, Watermark, Print Date, Two Colors, Divided Booklet, Creep Correction, Scan Lock Information, Tracking Information
Free Size, Sharpness, Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Single Color, Nega/Posi, Mirror Image, Repeat Images, Repeat Images (Auto), Framing, Blanking, Booklet Scanning, Do Not Booklet Scan, Between Batches, Copy Set Numbering, Watermark, Print Date, Two Colors, Divided Booklet, Creep Correction, Secure Watermark
Copy ID Card
Preset Zoom, Zoom by Percentage, XY Independent, Auto XY Ratio, Auto Zoom, Set by Length, Fit to Page, Automatic Paper Selection, Custom Size, Free Size, 1-Sided2-Sided, 2-Sided2-Sided, 2-Sided1-Sided, Book2-Sided, Poster (Number of Output Pages), Poster (%), Book2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Nega/Posi, Mirror Image, Repeat Images, Repeat Images (Auto), Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scan, Do Not Booklet Scan, Job Build, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Eco (Staple-Free), Saddle Stitch, Saddle Fold, Different Size Originals, Copy Sample, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Print & Check
*5 You can combine three modes at most among the following four modes: Page Numbering, Copy Set Numbering, Watermark, and Print Date.
Function
Auto (Color/Black)
Full Color*1, Black*1, Adjust One-Touch Color (Sepia Tone)*1, Single Color*1, Two Colors*1
Full Color
Auto (Color/Black)*1, Black*1, Adjust One-Touch Color (Sepia Tone)*1, Single Color*1, Two Colors*1
Black
Auto (Color/Black)*1, Full Color*1, Adjust One-Touch Color (Sepia Tone)*1, Single Color*1, Two Colors*1
Background Density (Adjust Each Color)*1, Background Density (Adjust All Color)*1, Poster (Number of Output Pages), Poster (%)
Background Density (Auto)*1, Background Density (Adjust All Color)*1
Background Density (Auto)*1, Background Density (Adjust Each Color)*1, Between Batches
Color Balance*1, Color Balance (Fine Adjust Density)*1, Between Batches, Secure Watermark, Scan Lock Information, Tracking Information
Auto (Color/Black)*1, Full Color*1, Black*1, Single Color, Between Batches, Page Numbering, Copy Set Numbering, Watermark, Print Date, Two Colors, Secure Watermark, Scan Lock Information, Tracking Information
Color Balance
Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction)*1, Between Batches, Secure Watermark, Scan Lock Information, Tracking Information
Single Color
Auto (Color/Black)*1, Full Color*1, Black*1, Adjust One-Touch Color (Sepia Tone), Two Colors*1, Secure Watermark, Scan Lock Information, Tracking Information
Two Colors
Auto (Color/Black)*1, Full Color*1, Black*1, Adjust One-Touch Color (Sepia Tone), Single Color*1, Page Numbering, Copy Set Numbering, Watermark, Print Date, Secure Watermark, Scan Lock Information, Tracking Information
