Top » Copy » Repeat Images
Repeat Images
0R9W-0RJ
This mode enables you to repeatedly copy the entire original image in either the vertical or horizontal direction.
Press [Copy].
Press [Options] → [Repeat Images].
Set the number of times that you want the image to repeat for both the vertical and horizontal directions.
Automatic Setting:
Manual Setting:
Automatic Setting:
Copies the image so that the maximum possible number of repeats fit on the selected paper size.
Press [Auto].
Manual Setting:
Copies the image the specified number of times.
Example: If "3 times" is selected
Images overlap when copied.
Press [-] or [+] to set the number of times that you want the image to repeat.
The repeated images may overlap or have gaps between them, depending on the number of repeats that you set.
4.
To specify the amount of the space between repeated images, press [Set Margins].
If you do not want to specify [Set Margins], proceed to step 6.
5.
Specify the amount of space to leave between repeated images using [-] and [+].
If you want to set the same width for all four borders:
If you want to set the width for each border independently:
Press [-] and [+] to set the amount of space → press [OK].
Press [Adjust Independently].
Select the space to adjust → press [-] and [+] to set the amount of space → press [OK].
To return to the screen for setting the same amount of space for all four sides, press [Uniform Width].
6.
Press [OK] → [Close].
