Top » Copy » Date Printing
Date Printing
0R9W-0RA
This mode enables you to print the date on copies.
Press [Copy].
Press [Options] → [Print Date].
Set the image orientation and print position → press [Next].
Orientation:
[Upright Image]:
Press this if you are placing originals upright.
[Sideways Image]:
Press this if you are placing originals sideways.
Upright Image
Sideways Image
Vertical Placement
Horizontal Placement
Vertical Placement
You can press [Set Details] to adjust the printing position.
To adjust the printing position, press [X] or [Y] → adjust the printing position with [-] or [+] → press [OK].
If you set any two of [Page Numbering], [Copy Set Numbering], [Print Date], or [Watermark] to print in the same position, a confirmation message appears when you press  (Start).
4.
Specify the print settings for the date.
Select the size of the date from the <Size> drop-down list.
Select the color of the date from the <Color> drop-down list.
Select the date format from the <Date Format> drop-down list.
Enter the desired date using - (numeric keys).
If no date is set, the date set in [Date/Time Settings] is printed. Confirm that the date and time settings are correct. (See "Current Date and Time.")
Press [Print Type].
Select the print type → press [OK].
If you select [Transparent], press [Light] or [Dark] to adjust the halftone density.
5.
Press [OK] → [Close].
Printing performance may not be optimal, depending on the original content and combination of settings.
If you use [Print Date] with [Add Cover] or [Insert Sheets], numbers will not be printed on the inserted pages.
