Top » Copy » Recalling Previous Copy Jobs (Previous Settings)
0R9W-0L0
This function enables you to recall the three most recent copy settings, and make copies using those settings.
Press [Copy].
Press [Options] → [Previous Settings].
Select the settings to recall → press [OK].
You can change the recalled copy settings before making copies.
4.
Press [Close].
Copy settings are counted as single recent copy settings until the following times: If they are not set as a single setting, the settings cannot be recalled with [Previous Settings].
When you press (Start)
When you press (Reset)
When Favorite Settings are recalled
The Standard mode cannot be recalled or stored.
Identical copy settings are stored only once in memory.
Once stored, the last three copy jobs are kept in memory even if the main power is turned Off.
