Top » Copy » Overview of This Function
0R9W-0KR
You can use various copy features from the Regular Copy Basic Features screen displayed on the touch panel display.
Copy Basic Features Screen
1
[Select Color]
Press to select the color mode for copying.
2
[Direct]
Press to make copies the same size as your original.
3
[Copy Ratio]
Press to specify the desired copy ratio.
4
[Select Paper]
Press to select the paper size/type and the paper source.
5
You can specify the following settings:
Register/Edit Favorite Settings
Register to Quick Menu (See "Quick Menu.")
Change Default Settings
Register Options Shortcuts
6
[Check Settings]
Press to check, edit, or clear the current copy settings.
7
Shortcuts to [Options]
Press to select an [Options] modes. (See "Assigning Shortcuts.")
8
[Options]
Press to specify other settings. You can configure a range of copy functions.
9
[Interrupt]
The interrupt mode enables you to pause a reserved or current job to make higher priority copies.
Options Screen 1/5
The screen below, which appears on the touch panel display when you press [Options] on the Regular Copy Basic Features screen, is called the Options screen. This screen is divided into three screens. Press  or to display the next or previous screen. All special copy modes appear on these screens.
Press after selecting a mode to display a Help screen containing guidance information. This is useful when you want to learn more about the selected mode.
1
[Favorite Settings]
Press to register frequently used copy settings. You can also recall registered settings.
2
[Previous Settings]
Press to recall the three most recent copy settings.
3
[Book2 Pages]
Press to select or deselect the Book2 Pages mode. This mode enables you to copy facing pages of an opened book onto separate copy sheets.
4
[2-Sided]
Press to specify the 2-Sided Settings. Press to make [1-Sided2-Sided], [2-Sided2-Sided], [2-Sided1-Sided], or [Book2 Pages] copies.
5
[N on 1]
Press to automatically reduce two or four page originals to fit onto a one-sided or two-sided copy sheet.
6
[Job Build]
This mode enables you to scan multiple originals that are too many to be placed at once, by dividing them into multiple batches.
7
[Booklet]
Press to make a booklet by copying several originals.
8
[Finishing]
Press to select the Collate, Group, or Staple mode.
Options Screen 2/5
1
[Add Cover]
Press to add covers.
2
[Insert Sheets]
Press to insert sheet insertions, chapter pages, or tab paper between specified pages.
3
[Different Size Originals]
Press to make copies of different size originals by placing them as a group in the feeder.
4
[Density]
Press to adjust the copy density.
5
[Document Scan Lock]
Press to embed hidden information in copies. This increases security by preventing unauthorized copies.
6
[Secure Watermark]
Press to embed hidden text in the background of the print. The hidden text will become visible if the resulting output is copied.
7
[Transparency Cover Sheets]
Press to insert a sheet between each transparency when copying transparencies. You can also copy on the inserted sheets.
8
[Original Type]
Press to select the type of original ([Text/Photo/Map], [Printed Image], [Photo Printout], or [Text]) you are going to copy.
Options Screen 3/5
1
[Color Balance]
Press to make color balance adjustments.
2
[Adjust One-Touch Color]
Press to make fine adjustments to the image quality on copies.
3
[Page Numbering]
This mode enables you to print page numbers.
4
[Copy Set Numbering]
This mode enables you to print copy set numbers.
5
[Print Date]
This mode enables you to print the date.
6
[Watermark]
This mode enables you to print a watermark.
7
[Erase Frame]
Press to eliminate dark border areas, lines that appear around original images, or shadows from binding holes.
8
[Sharpness]
Press to sharpen or soften the original image on the copy.
Options Screen 4/5
1
[Shift]
Press to shift the position of the original image on the copy.
2
[Gutter]
Press to create gutters along the sides of the copy.
3
[Print & Check]
Press to confirm scanned images page by page before copying when you scan originals on the platen glass.
4
[Nega/Posi]
Press to make copies of the original image by inverting the gradations of black-and-white.
5
[Job Done Notice]
Press to have the machine notify the user through e-mail when the copy job is done.
6
[Mirror Image]
Press to copy the original image reversed, as if it were a reflection in a mirror.
7
[Repeat Images]
This mode enables you to repeatedly copy the entire original image in either the vertical or horizontal direction.
Options Screen 5/5
1
[Copy ID Card]
Press to line up and copy both the front and back of a ID card, such as a driver's license onto a single sheet of paper.
2
[Area Designation]
Press to make copies of a designated area.
