Top » Copy » Copy Sample
Copy Sample
0R9W-0KY
This mode enables you to check the copy result before making multiple copies.
[Copy Sample] appears only if you set to make multiple copies of your original in [Collate (Page Order)], [Offset], [Rotate 90 Degrees], [Staple], [Add Cover], [Insert Sheets], [Booklet], or [Transparency Cover Sheets].
Press [Copy].
Set the desired copy modes → press [Copy Sample].
Select the pages to print a sample copy for.
If you select [All Pages]:
If you select [Specified Pages]:
Press [All Pages].
Press [OK].
Press [Specified Pages].
Press [First Page] and [Last Page] → press [-] or [+] to set their respective page numbers.
Press [OK].
4.
Press (Start).
Check the content of the output.
The following restrictions apply when specifying pages:
Make sure to specify page numbers based on the output. Note that the page numbers of the output may be different from those of the original.
The Staple, Saddle Stitch Booklet, and Saddle Fold mode cannot be set.
You cannot change the specified page numbers after the copy sample is output.
You cannot change [All Pages] to [Specified Pages] or vice versa after the copy sample is output.
5.
Select the desired operation.
To make the remaining copies, press [Start Copying].
To change the settings, press [Change Settings]. Select the mode to change → after pressing [Change], change the settings → press [OK].
If you want to check the changes that you have made, press [Copy Sample] → repeat the procedure from step 2.
If you change settings and then press [Start Printing], the machine copies from the first set with the new settings.
To cancel copying, press [Cancel].
If you select [All Pages], the machine's counter counts the sample set as a copy.
