You can reserve copying while the machine is in the waiting state at the following times:
Between the time that you turn the machine On and when it is ready to copy
After you clear a paper jam
Directly after you close a cover on the main unit or an optional unit, such as a finisher
You can reserve up to 20 copy jobs, including the current job. Interrupt copy jobs are not included in this count.
You can set different copy modes and paper sources, including the multi-purpose tray, for each reserved job.
If [Multi-Purpose Tray Defaults] is set to 'Use Preset' in Device Use Settings, reserved printing can be performed only for the registered paper size and type. (See "Setting the Method for Selecting Multi-Purpose Tray Paper.")
For more information on paper types, see "Available Paper Stock."
