This mode can be used only for printing a file stored in a mail box or a PDF or XPS file.
The Saddle Stitch and Fold modes can be used only for printing a file stored in a mail box.
Be sure to correctly set the paper type. If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty, or the paper could jam, and a service repair may be needed.
The Finishing modes cannot be set if envelope, transparencies, or labels is selected.
Only 14 to 28 lb bond (52 to 105 g/m2) paper can be used for the main document.
[Saddle Stitch] can be set only if two-sided printing is set.
The accuracy of folds created in the Saddle Stitch mode may vary, depending on the paper type and the number of sheets.
The Saddle Fold Mode can be used only for printing a file stored in a mail box.
The Saddle Fold mode can be set only if 2-Sided Printing is set.
The paper is saddle folded one sheet at a time, and then output.
You can only set [Rotate 90 Degrees] in the following cases:
When a finisher is not attached:
When the Inner Finisher-G1 and Copy Tray-J2 are attached and only Tray C is specified as the output tray in [Output Tray Settings] (See "Output Tray Designation.")
When the Staple Finisher-U1 or Booklet Finisher-U1 are attached and only Tray C is specified as the output tray in [Output Tray Settings] (See "Output Tray Designation.")
If [Paper Drawer Auto Selection On/Off] for the selected paper source is set to 'On' (See "Enabling Paper Drawer Auto Selection.")
If there is no paper which can be rotated, the output will be collated.
Optional Unit
Collate (Page Order)
Group (Same Pages)
Offset
Rotate 90 Degrees
Staple
Saddle Fold
Corner
Double
Eco (Staple-Free)
Saddle Stitch
None
Copy Tray-J2
Inner Finisher-G1
Inner 2way Tray-J1
Inner 2way Tray-J1 and Copy Tray-J2
Staple Finisher-U1
Booklet Finisher-U1
*1
Can be set when only Tray B is specified as the output tray in [Output Tray Settings] (Settings/Registration).
*2
Can be set only when a tray other than Tray A is specified as the output tray in [Output Tray Settings] (Settings/Registration).
*3
Can be set when only Tray C is specified as the output tray in [Output Tray Settings] (Settings/Registration).
Paper Size
Corner
Double
Staple Free
12" x 18"
12 5/8" x 17 11/16"
11" x 17"
30 sheets
30 sheets
5 sheets
LGL
30 sheets
30 sheets
LTRR
30 sheets
30 sheets
LTR
50 sheets
50 sheets
5 sheets
EXEC
50 sheets
50 sheets
STMTR
STMT
Paper Size
Corner
Double
Saddle Stitch*
12" x 18"
16 sheets
12 5/8" x 17 11/16"
11" x 17"
30 sheets
30 sheets
16 sheets
LGL
30 sheets
30 sheets
16 sheets
LTRR
30 sheets
30 sheets
16 sheets
LTR
50 sheets
50 sheets
EXEC
50 sheets
50 sheets
STMTR
STMT
For information on the original orientation and paper orientation when performing stapling, see "Relationship Between the Original Orientation and Paper Orientation."
If you set [Corner] or [Double], the side of the paper which is printed on will always be output face down.
For information on optional products, see the following:
If [Finishing] is not set, the settings are the same as when [Group (Same Pages)] is set.
You can display the detailed information of the selected paper by pressing
