0R9W-14S
You can check the detailed information (folder name, location, date modified, etc.) for folders in memory media.
You can also create new folders.
Checking the Detailed Information for a Folder
Press [Access Stored Files] → [Memory Media].
Select the desired memory media → select the desired folder level → press [Folder Operations].
Select the desired folder → press [Details] → [OK].
If you want to change the folder name, press [Rename Folder].
4.
Press [OK].
Select the desired memory media → select the directory where you want to create the new folder → press [Folder Operations].
Press [Create Folder].
4.
Enter a name for the folder → press [OK].
5.
Press [OK].
