0R9W-14W
You can preview the contents of files stored in memory media.
Press [Access Stored Files] → [Memory Media].
Select the desired memory media → select the directory where the file you want to display is stored.
Select the desired file → press [Display Image].
If you select multiple files, only the contents of the selected (highlighted) files are displayed.
To preview an encrypted PDF file, it is necessary to enter the password on the password entry screen.
To preview a PDF file with a policy, it is necessary to enter the user information on the login screen.
4.
Press
to select the page to check → check the image.
You can press
(reduce) or
(enlarge) to zoom in or out.
You can press
, or
to specify the area to display when you zoom in or out on the page.
5.
Press [OK].
