Top » Access Stored Files » Enlarging and Reducing Prints
0R9W-163
You can adjust the image size of JPEG and TIFF files to match the paper size when printing.
As an example, the procedure for printing files that are stored in memory media is explained in this section.
This mode is only available for printing files stored in the Advanced Box of another imageRUNNER ADVANCE machine on the network or memory media.
You can use this mode only when printing JPEG or TIFF files.
Press [Access Stored Files] → [Memory Media].
Select the desired memory media → select the location where the file you want to print is stored.
Select the desired file → press [Print].
4.
Select the paper source → press [OK].
5.
Press [Options] → [Enlarge/Reduce] → [Close].
To change the paper source, see "Paper Selection."
