This mode can be used only for printing a file stored in a mail box or a PDF or XPS file.
The Saddle Stitch and Divided Booklet modes can be set only if the Booklet Finisher-U1 is attached.
Be sure to correctly set the paper type. When printing on special types of paper, such as heavy paper, be sure to correctly set the paper type, especially if you are using heavy paper. If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty and require a service repair, or the paper could jam.
[Booklet Scan] can only be specified for the following record sizes: LTR, LTRR, STMT, or STMTR.
The Booklet mode cannot be set if multiple files are selected, and their record sizes are different.
Mail Box
Network/Memory Media
Mail Box
[Fold Only] can be used only for printing a file stored in a mail box.
The maximum number of sheets that can be saddle stitched at one time is 16. If you want to saddle stitch 17 or more sheets, set the Divided Booklet mode.
If the number of sheets is 17 or more, the booklet is not saddle stitched.
You can select the type of finishing only if [Booklet Scan] is set.
[Set Details] can be used only for printing a file stored in a mail box.
The number of saddle stitched booklets that the booklet tray can hold depends on the number of sheets that each booklet contains.
You can set [Change Fold/Stitch Pos.] only if you select [Fold + Saddle Stitch].
12" x 18"/11" x 17"/LGL
LTRR
Make sure to set the Booklet Tray guide to match the paper size. Setting the Booklet Tray guide incorrectly may result in a paper jam.
Saddle stitching is not performed if there is only one output sheet.
The accuracy of folds may vary, depending on the type and quantity of paper.
