Top » Access Stored Files » Arranging Files Stored in a Mail Box » Operations for Files Stored in a Mail Box
0R9W-14C
You can add, delete, and rename files stored in a mail box.
Deleting a File
Press [Access Stored Files] → [Mail Box].
Select the desired Mail Box → select the desired file → press [Edit File/Other].
Press [Delete].
4.
Press [Yes].
Changing a File Name (Change File Name)
Press [Change File Name].
If you select multiple files and press [Change File Name], the selected (highlighted) file name will be changed.
4.
Enter a file name → press [OK].
Printing Lists
You can print a list of files stored in a mail box.
Select the desired Mail Box → press [Edit File/Other].
Even if you sort the list of stored files by pressing [Name] or [Date/Time], the list of files will be printed in the order that the files were stored in the mail box.
Press [Print List].
4.
Press [Yes].
Lists can be printed only if 11" x 17", LGL, LTR, or LTRR paper (plain, recycled, thin, or color) is loaded in a paper drawer that is set to 'On' in [Other] in [Paper Drawer Auto Selection On/Off] in [Function Settings] (Settings/Registration). However, if [Consider Paper Type] for [Copy] is set to 'On' in [Paper Drawer Auto Selection On/Off], you cannot print from a paper drawer with color paper specified. (See "Enabling Paper Drawer Auto Selection.")
The following information is printed: mail box number/name, type of file, file name, paper size, number of pages, user name, and date and time.
Adding a File (Scan and Store)
You can scan an original and store it as a file.
Place your originals.
For instructions on placing originals, see "Placing Originals."
4.
Press [Add Files (Scan and Store)].
5.
Specify the desired scan settings.
6.
Press (Start).
If the following screen is displayed, after the last batch of originals is scanned, press [Start Storing].
If you place your original on the platen glass, press (Start) to scan each original.
