Resolution
Gradation
Error Diffusion
This mode is only available for printing files stored in the Advanced Box of another imageRUNNER ADVANCE machine on the network or memory media.
You can use this mode only when printing JPEG, TIFF, PDF, or XPS files.
[Resolution]:
A dither pattern that gives priority to the resolution of the images is used. This helps eliminate the appearance of jagged or uneven lines along the edges of objects and is best for printing standard text and graphics.
[Gradation]:
A dither pattern that gives priority to the appearance of smooth changes in tone is used. This is best for reproducing images with delicate gradations or changes of tone.
[Error Diffusion]:
This mode uses an error diffusion method that is excellent for fine expressions such as text and thin lines.
It enables you to print in even finer detail than the [Resolution] mode. You may however experience a slight drop in the integrity of the image quality. It is suited for printing small characters and fine lines in particular.
