Top » Access Stored Files » Convenient Modes for Printing
0R9W-157
You can use [Options] from the Print Settings screen to access a wide variety of print options to meet your needs.
You can set the Enlarge/Reduce mode, set the print resolution, and specify many other print options.
The options that you can use differ based on the file format. The following options are supported for each file type:
: Available
-: Unavailable
Options
Storage
Mail Box
Network
Memory Media
File Format: PDF
Network
Memory Media
File Format: XPS
Network
Memory Media
File Format: TIFF/JPEG
[Booklet]
[Shift]
[Secure Watermark]
[Document Scan Lock]
[Gutter]
[Page Numbering]
[Copy Set Numbering]
[Watermark]
[Print Date]
[Color Balance]
[Adjust One-Touch Color]
[Resolution]
[Halftones]
[Match Paper Size]
[Enlarge Print Area]
[N on 1]
[Print Comments]
[Password to Open a Doc.]
[Enlarge/Reduce]
[Image Orientation]
[Print Position]
Depending on the mode, some combinations of modes are not available. (See "Unavailable Combination of Functions.")
