Top » Access Stored Files » Two-Sided Printing
Two-Sided Printing
0R9W-156
This mode enables you to print two successive pages of a stored file, on both sides of a sheet of paper.
As an example, the procedure for printing JPEG and TIFF files that are stored in memory media is explained in this section.
Press [Access Stored Files] → [Memory Media].
Select the desired memory media → select the location where the file you want to print is stored.
Select the desired file → press [Print].
If you selected a file in a mail box, press [Change Print Settings] → proceed to step 5.
If you select a PDF or XPS file, proceed to step 5.
4.
Select the paper size → press [OK].
5.
Press [2-Sided Printing].
To change the paper source, see "Paper Selection."
6.
Select the type of finishing → press [OK].
If [Mail Box] is selected in step 1, you can select one of the following types of two-sided printing.
[Book Type]:The front and back sides of the print have the same top-bottom orientation.
[Calendar Type]:The front and back sides of the print have opposite top-bottom orientations.
If [Network] or [Memory Media] is selected in step 1, you can select one of the following types of two-sided printing.
[Long Edge]:
Uses the long edge of the paper as the binding location for the back and front sides.
[Short Edge]:
Uses the short edge of the paper as the binding location for the back and front sides.
7.
Press [Start Printing].
You may not be able to print, depending on the paper type.
Paper used to make two-sided prints must conform to the following specifications:
Paper size: Custom Size (5 1/2" x 7 1/8" to 12 x 18" (139.7 mm x 182 mm to 304.8 mm x 457.2 mm)), 12" x 18", 11" x 17", LGL, LTR, LTRR, STMTR, EXEC (envelopes cannot be used for two-sided printing)
Paper weight: 14 lb bond to 80 lb cover (52 to 220 g/m2)
If there are an odd number of pages in the file, the back side of the last print is left blank. (The machine's counter does not count the blank page as a print.)
If you select a PDF file together with the Auto Select Paper mode, and the pages that you want to print are of different sizes, the pages are printed as one-sided prints on paper of their respective sizes. If you want such pages to be printed as two-sided documents, select the correct paper sizes in advance.
