Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending a Fax from a Computer (Windows) » Exporting Address Book Entries
07SE-0UL
You can save data registered in the address book as a CSV (*.csv) file or a Canon Address Book file (*.abk). You can use the saved file in other applications.
Click [Edit Address Book] → [Export].
See "Faxing" or "Specifying the Default Fax Settings" on how to display the fax driver screen.
If you have selected [Protect with Password when Exporting Address List] in the [Security Settings] dialog box of the [Special] tab, a dialog box for entering a password is displayed when you click [Export]. For details, see the online help (see "Viewing the Online Help").
Enter the file name → click [Save].
Select the type of the file to export from [Save as type]: CSV Files (*.csv) or Canon Address Book (*.abk)
If you have selected a CSV file, specify the separators used in the file.
The specified address book is saved as a file.
You cannot access or edit the address book if you do not have access permission to the destination folder of the address book. If this is the case, log on as a user having access permission to the folder, or click [Specify a Folder] in the [Edit Address Book] tab, and change the destination folder of the address book to a folder that you have write permission for (see "Changing the Address Book Export Destination").
The display may vary according to the operating system and system environment.
