Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending/Receiving a Fax » Specifying Destinations
07SE-0R1
You can select a destination stored in the Address Book or a one-touch button, or specify a new address altogether. You can also recall destinations and settings for fax in Previous Settings and specify destinations on the Log screen for [Send] on the Status Monitor/Cancel screen.
If the Destination Is Stored in the Address Book
If You Want to Specify Destinations Using the New Address
Specifying Destinations Using the Useful Functions
Checking/Changing/Deleting Destinations
If you specify and send to an address not stored in the Local Address Book, it is not automatically added to the Address Book. It is deleted once the document is sent.
If a group destination includes a destination other than fax, you cannot send your fax.
To view the detailed information for a selected destination, select the destination → press [Details].
You can change, edit, or delete destinations on the Fax Basic Features screen before scanning. (See "Checking/Editing/Deleting the Information for a Destination.")
You can specify a maximum of 256 destinations at the same time. However, if a group address is specified for the destination, each address stored in that group is counted as one destination.
If you frequently send documents to the same destinations, store these destinations in the Local Address Book beforehand. (See "Storing New Addresses.")
