Size of Received Document
Paper Size Priority
11" x 17"
11" x 17" → LTR* → LTRR* → LGL* → STMTR x 2
LGL
LGL → LTR x 2 → LTRR x 2 → STMTR x 2 → 11" x 17"
LTR
LTR → LTRR → LGL → STMTR x 2 → 11" x 17"
STMT
STMTR → LTR → LTRR → LGL → 11" x 17"
Received documents can be printed on the following paper sizes and paper types:
Size: 11" x 17", LGL, LTR, LTRR, or STMTR
Paper Types: plain, recycled, color, or custom paper type (paper with the following settings; Paper Weight: 17 to 28 lb bond (64 to 105 g/m2), Type: Normal, Finish: Uncoated or Recycled)
You can specify each paper drawer for the fax function. The default setting is 'On', except for the multi-purpose tray. (See "Enabling Paper Drawer Auto Selection.")
You can set the machine to reduce received documents in 1% increments between 75% to 97% if the document is larger than any of the available paper sizes. (See "Reducing a Received File.")
You can change the order of paper selection. (See "Paper Drawer Selection.")
You can set the machine to print received documents on both sides of the paper. (See "2-Sided Printing.")
