Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending/Receiving a Fax » When Problems Occur » Trouble Receiving Fax Documents
07SE-0SW
The machine cannot receive documents.
Does the machine have sufficient memory?
Delete unnecessary documents and documents with errors from memory to increase the amount of available memory.
(See "Checking the Detailed Information for/Deleting a File in the Memory RX Inbox.")
The machine cannot receive faxes.
Is an RX password set in [Fax Settings] in your machine?
If an <RX Password> is set in Fax Settings, documents can be received only from senders that use the correct password. Confirm this with your administrator. (See "Setting the Receive Password.")
Cannot forward documents to the Confidential Fax Inbox.
Are the forwarding conditions set correctly?
Check the Forwarding Conditions, and inform the sender of those settings. (See "Storing Forwarding Settings.")
Is Forwarding Settings set to 'On' using [Validate/Invalidate]?
Forwarding Settings must be set to 'On' to be effective. Press [Validate/Invalidate] for [Forwarding Settings] → set Forwarding Settings to 'On'. (See "Storing Forwarding Settings.")
Delete unnecessary documents and documents with errors from memory to increase the amount of available memory. (See "Checking the Detailed Information for/Deleting a File in the Memory RX Inbox")
Delete unnecessary documents from the Confidential Fax Inboxes. (See "Checking the Detailed Information for/Deleting a File in a Confidential Fax Inbox.")
Cannot receive documents to memory.
Delete unnecessary documents and documents with errors from memory to increase the amount of available memory. (See "Checking the Detailed Information for/Deleting a File in a Confidential Fax Inbox")
Delete unwanted documents from the Memory RX Inbox. (See "Checking the Detailed Information for/Deleting a File in the Memory RX Inbox.")
The quality of printed originals is uneven.
Is the platen glass of the sender's machine clean?
Make a few copies using your machine. If the copies are not streaked, the problem is in the sending party's machine. Contact the sender and ask them to send the document again.
