Setting the Memory Lock Mode
07SE-0SF
You can set to store received fax documents in the Memory RX Inbox without printing them. You can later check the received documents in the Memory RX Inbox, and print or send them as necessary.
If you set [Fax Memory Lock] to 'On', you can specify the settings for <Fax Memory Lock> for the Memory RX Inbox as necessary. (See "
Specifying the Fax/I-Fax Inbox Settings" and
"Memory RX Inbox.")
You cannot store received documents in the Memory RX Inbox in the following cases. (These numbers may vary depending on the remaining capacity of the memory.)
When a total of 1,500 documents have been stored in the Fax/I-Fax Inbox
When a total of 6,000 pages have been stored in the Fax/I-Fax Inbox
