Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending/Receiving a Fax » Forwarding Received Documents
07SE-0SH
You can set to automatically forward received fax documents that conform to specified forwarding conditions to a specified destination. You can register the forwarding conditions and destinations in Forwarding Settings. (See "Storing Forwarding Settings.")
To be able to forward received documents, you must first set [Validate/Invalidate] to 'On' in [Forwarding Settings]. (See "Storing Forwarding Settings.")
