Category
Top » Problem Solving » Clearing Paper Jams » Reducing the Frequency of Paper Jams
Category Top
Clearing Paper Jams
Locations of Paper Jams
Main Unit
Paper Sources
Paper Drawer
Cassette Feeding Unit-AF1 (Optional)
Paper Deck Unit-B2 (Optional)
Feeder
Staple Finisher-G1/Booklet Finisher-G1 (Optional)
Inside the Top Cover
Buffer Pass Unit-H1
External 2/3 Hole Puncher-B2
Inside the Front Cover
Saddle Stitcher Unit
Inner Finisher-D1 (Optional)
When the Inner 2/3 Hole Puncher-A1 Is Not Attached
When the Inner 2/3 Hole Puncher-A1 Is Attached
Inner 2Way Tray-H1 (Optional)
Clearing Staple Jams (For Optional Products)
Locations of Staple Jams
Saddle Stitcher Unit of the Booklet Finisher-G1
Inner Finisher-D1
If Memory Becomes Full during Scanning
Printer/Fax Driver Troubleshooting
Service Call Message
List of Error Messages
General
Fax
Scan and Send
Scan and Store/Access Stored Files
Quick Menu
Printer
Network
MEAP
User Setting Information Management
List of Error Codes without Messages
Collapse all|Expand all
If paper jams occur frequently, even though there is no apparent problem with the machine, either one of the following two reasons may be the cause. Follow the instructions described below to reduce the frequency of paper jams.
There are torn pieces of paper left inside the machine.
Pulling jammed paper out of the machine by force may leave parts of the paper torn inside, leading to frequent paper jams.
If paper tears while you are trying to remove jammed paper from the machine, make sure that you remove all of the torn pieces.
The paper is not loaded correctly in the paper drawer.
Make sure that the paper size plate of the paper drawer matches the size of the paper loaded in the paper drawer.
