If the Paper Deck Unit-B2 is attached, move the paper deck unit away from the main unit before proceeding with this procedure.
1. Open the paper drawer's upper right cover, holding it by its handle.
2. Remove any jammed paper.
3. Close the paper drawer's upper right cover.
CAUTION |
When closing the cover, be careful not to get your fingers caught, as this may result in personal injury.
Gently close the cover until it clicks into place in the closed position.
1. Press the open button of the paper drawer.
2. Grip the handle, and pull out the paper drawer until it stops.
3. Remove any jammed paper.
CAUTION |
When returning the paper drawer to its original position, be careful not to get your fingers caught, as this may result in personal injury.
If the Paper Deck Unit-B2 was moved away from the main unit, reconnect it to the main unit.
The screen indicating the directions on how to clear the paper jam is displayed repeatedly until the paper jam is cleared.
