Category
Top » Problem Solving » Clearing Staple Jams (For Optional Products) » Saddle Stitcher Unit of the Booklet Finisher-G1
Category Top
Clearing Paper Jams
Locations of Paper Jams
Main Unit
Paper Sources
Paper Drawer
Cassette Feeding Unit-AF1 (Optional)
Paper Deck Unit-B2 (Optional)
Feeder
Staple Finisher-G1/Booklet Finisher-G1 (Optional)
Inside the Top Cover
Buffer Pass Unit-H1
External 2/3 Hole Puncher-B2
Inside the Front Cover
Inner Finisher-D1 (Optional)
When the Inner 2/3 Hole Puncher-A1 Is Not Attached
When the Inner 2/3 Hole Puncher-A1 Is Attached
Inner 2Way Tray-H1 (Optional)
Reducing the Frequency of Paper Jams
Locations of Staple Jams
Inner Finisher-D1
If Memory Becomes Full during Scanning
Printer/Fax Driver Troubleshooting
Service Call Message
List of Error Messages
General
Fax
Scan and Send
Scan and Store/Access Stored Files
Quick Menu
Printer
Network
MEAP
User Setting Information Management
List of Error Codes without Messages
Collapse all|Expand all
Check the location of the staple jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed staple.
Make sure to close all covers and paper drawers of the machine before clearing any staple jams.
Before clearing a staple jam in the saddle stitcher unit, remove all paper that has been output to the booklet tray.
The Booklet Finisher-G1 is an optional product.
Open the front cover of the finisher.
Pull out the saddle stitcher unit.
1. Grip the handle of the saddle stitcher unit, and pull out until it stops.
2. Pull the stapler unit of the saddle stitcher unit towards you, and then push it up.
Pull out the staple case containing the jammed staples, holding it by its left and right sides.
4.
Push down the tab on the staple case.
1. Push down Part A to unlock.
2. Push up Part B.
5.
Remove any jammed staples.
1. Remove any jammed staples.
2. Return Part B to its original position.
6.
Return the staple case to its original position.
Push the staple case in until it clicks into place.
7.
Gently push the saddle stitcher unit back into its original position.
1. Pull the stapler unit towards you, and then push it down into its original position.
2. Grip the handle of the saddle stitcher unit, and return it to its original position.
CAUTION
When returning the saddle stitcher unit to its original position, be careful not to get your fingers caught, as this may result in personal injury.
8.
Close the front cover of the finisher.
CAUTION
When closing the cover, be careful not to get your fingers caught, as this may result in personal injury.
When you have cleared the staple jam, be sure to manually reposition the staples in the saddle stitcher unit. (See "Saddle Stitch Staple Repositioning.")
